Hello everybody,
I am looking at the differences of the M119 versions to learn more about them, and distinguish the characters performance wise.
For example I have found that the M119.975 and .985 share the same part numbers for all important parts such as camshafts, valves, pistons, conrods etc.
The inlet manifolds are identical part numbers of the .980(E50 AMG) and .985, but the .975 and .974 have different inlet manifolds. In what do they differ?
The exhaust valves appear to be the same for all M119 after the decrease to 7mm stem, but for the .98x, the inlet valve differs similar to the .97x inlet valves, regarding part numbers.
What amused me is that the .975 and .985 seems to be the exact same engine except for the EMS and cylinder heads, but the .97x engines seem to be totally different.
So the question is what distinguish the different parts numbers?
what are the inlet valve diameter of the .97x and the .98x engines? what differs from the camshafts in terms of lift, duration and timing?
Would use this information to get a little more meat on the legs before I start to modify my .975 engine.
is the crankshaft interchangeable between all models? there seems to be a least 4 different crankshaft part number for each .97x and .98x ?? what differes them except for the different stroke of .975/.974?
A long stroke .975 would probably be better in both aspects of consumption and performance.
the question is how to take advantage of the best parts, that can be salvaged and quite cost effective?
the next question is if there is any noticeable improvement of the engine by the change to Motronic EMS from the LH? except from the emissions aspect, would there be any improvement to driveability? As I know of, there is more information about doing an eprom dump and cracking the fuel and ignitions maps for the Motronic, than the LH, which could be useful for any tuning work that relates to these engines.
despite my little experience with the M119, I hope someone would take their time to try and help fill up this thread with good information.
cheers
Truls
cheers
Truls
