Dear all,
I am a proud new owner of a '93 400 E and enjoy the car really much.
However since I bought the car and drove about 1000 km the oil pressure started to drop.
Since I need the car in working condition and need it to be reliable I ordered new plastic oil tubes, oil pressure sensor and spring relief valve without hesitating.
However, today when I changed the thermostat, I forgot that I could see the oil tube from the filler cap (at least one of them) and noticed that I have the metal tubes.
From what I read I was sure that my car should have plastic ones, and that was the problem causing the lowered pressure.
The gauge stays at 3 during warmup, but is around 2.25 when the engine is warm.
Would please need some advice on how to proceed. Should I dissasemble the valve covers and clean my existing tubes, and replace the seals with those from the plastic ones, or should I change them to the plastic ones completely, or should I simply don't open the valve covers at all, and chance that the sensor is default?
I am aware of that I can return the plastic ones to the dealer and just buy the orings, but I cant wait for the new order.
I have seem that in most cases the oil tubes are the problem, if not could it be just the seals? Or is this not an issue?
Should I change the pressure relief valve inside the filter housing at the same time, or just leave it with the sensor when I am at it?
the problem is that I will drive the car for 700 km during the weekend, and have only tomorrow to fix the problem.
thanks for any help
best regards
Truls
thanks for any help
best regards
Truls
