Re: M119 chokes at 4250 rpm..? - MAS..replaced..EZL replaced
The valve cover gaskets R&R is quite straight forward. Shouldn't take you more than a couple of hours. The hex bolts towards the firewall are a pain in the arse to get out if you don't have a swivel adapter to remove them. On the passenger side bank, towards the rear you will see rubber tubing, I think they are referred to as 'oil tubes'. If they look brittle and dried up, it will be a miracle if you can remove them without having them break so you can refit them. In general, be careful with all the rubber tubing going into the valve covers.They WILL break if they are old. So probably plan on adding those to the list as well.
A quick check that will bring having to replace the valve cover gasket from your top priority list, is going over the edge with a paper towel, if its leaking bad you will see it on the paper, (if you haven't by plain sight). So, unless the leak is bad enough to get into you caps and the camshaft sensor's I wouldn't panic. Next you want to remove your spark plugs one by one. Check the threads for any oil on them. If they have engine oil on them and specially around the lateral electrode, then the round seals on the valve cover gaskets are seeping into the plugs. Not fatal but a definite performance inhibitor and it will give you a misfire like symptom..
The slight tapping noise you hear are either your lifters and/or the camshaft oil lube tubes, all of which are accessible while replacing the valve cover gaskets. I think I mentioned it before..? Both are not that expensive $15-$25. Camshaft tubes easily replaced, lifters...not so much.. I did some in an Integra a while back and it was a pain..
The hydraulic system is an isolated system operating only on the principles of Force, Pressure and Area, (Pascals Law) and is independent of engine performance. Sure you will have a hard time steering if it goes, but thats about it.. What I found to be a common issue besides the seal rings leaking on the steering rack was the short, (about 2" long) high pressure return hose on the bottom of the Power Steering reservoir. No exceptional skills required to replace it but it takes some time and removing a lot things around it. Again, its just a leak and unless it's emptying your reservoir I wouldn't panic.
