M119 engine coughs, stutters, backfires, won't rev
That I reacently experienced, the Beru caps I have had some time, worked just fine and looked very, almost new inside BUT when the
motor had been driven varm/hot for some 20min. at hard acceleration round 140km/h several times it felt like almost starvation!
A slight feel of a disturbed idle and when at a red light in gear,I had to selekt N, I have been through this Before and it was SO VERY
obvious, DAMN them Distr.caps. Back home, a change to the used Bremi Caps&rotors, What do you Think.....Sweet as Tupelo Honney
Now I ordered new items from not MB but a parts dealer here, BOSCH delivered, must be same as oem but some 200+ € less with
my discount. Not taking any more risk, buying from internet anymore...........
I hate to rain on your parade, but this has been discussed multiple times... bad insulators cause a misfire which is "cured" by different caps and/or rotors. Until the same thing happens again a few months later, with the "new" caps/rotors. And then new caps/rotors cure the problem... until it happens again, and again. I wouldn't be so quick to bash on the Beru caps as the problem. Also, I've personally had a defective brand-new Bosch cap, straight out of the box (again, I'd posted this multiple times) which caused a misfire at hot idle. Bosch is not necessarily any better. And Bremi is not OEM for any M119 ignition parts.
So. Do you have new insulators in this engine? And how many miles were on the "defective" Beru caps?
:watchdrama: :klink3:
Am I correct in thinking this issue is also being discussed on another forum as below?-
http://www.benzworld.org/forums/w124-e-ce-d-td-class/2853426-400e-dies-when-gets-hot-still.html
Yes, I believe they are the same person / car.
Maybe this is not you – but the posts seem to relate. Maybe you could take a couple of minutes to fill out your profile on 500E board.
+eleventybillion, for every forum member. I wish we could make location and vehicle info required fields during registration.
For completion of the query on here some of the posts might prove useful. The information on there suggests used insulator discs were fitted. I agree with GSXR that your case sounds like classic failing insulators.
That's my understanding too, used parts were fitted, but new ones MAY be on the way.
The Bremi, who said it was oem? I had a set used, and they cured the problem for now, new BOSCH on the way, and not via ebay, so they are for sure BOSCH!
The insulator, what does it do exept keeping out mostly staubschuts or dustcover and moisture/dampness? there is no high tension voltage below the rotor
if the spark goes the right way, when humidity gets in there, the cover does not seem to do it's job there, spark takes it's easiest way in there....
I do not really know for sure, but mentioned clear coat on a cleaned dustcover, inside, would that not do the same "job" as a new one?
The caps, do not look too bad, same with the rotors, I guess the resistance inside Changes at high temp? Maybe it burns out and forces
the spark to jump within the resistor, I should open one cap and see. You can not judge the condition of a cap just by looking at the Surface.
So much have I learnt, maybe I should get the E50 ready and not Think of the caps, anyway, allthough more complex, the ign. issue is not there.
Hi. I have an E500 with some 90kkm on it, that I bought a few months ago. The car had been sitting from quite some time, but we did the full recommissioning and service routine, and also changed plugs, rotors, caps, and plug wires. Initially the car worked great, but gradually developed a misfire, like described above. We found the distributor caps were wet inside, and the insulators had measles. On your advice I changed the insulator caps to have all parts new, and the car's running improved tremendously, and there seemed to be more power available. (We did the same thing to my friend's 500E as well.) Well, the joy lasted only about 3 days, before the misfire returned. It's been raining..... Could this be moisure having returned? I will obviously check again, but it seems somewhat strange that a 90s Merc can't take a rainshower...... If there is moisture in there, what do I do (after cleaning and drying things out)? If not, what do I look at next? Has anyone found out more?
Just want to be sure they are proper fir the car without the R in the number and nothing platinum or fancy, also gapped to approx 1.0
Also just about the “miss”... torque spec matters on the plugs too, wire resistance bad out if the box. Bad mounts can translate slightest shutter even if the compressor turn on or
Off. GSXR or Klink are better than me on this...
Just curious, what brand of caps, rotors, insulators, and wires were installed? Also need to confirm correct plug type / part number although the 'wrong' plugs should not cause a misfire, unless fancy fine-wire plugs were installed (these engines don't like those). With all new parts and correct plugs, it SHOULD be running fine, regardless of weather / humidity / rainshowers. Is the misfire only at idle, or on acceleration, or...?
BTW, congrats on the recent E500 purchase, and welcome to the forum!
:welcome4:
my E420 had blocked cat and blocked exhuast mufflers from sitting too long and not used. Was not revving and had a very bad idle. Sometimes would not even start.
I want to thank everyone here who suggested replacing the insulators. I had power/misfire problems when warm (I described it in a post months ago but I can't find it). I just replaced the insulators and it's a totally different car. Thank you all.
E420
Brief update: I haven't been on here since last fall as winter came before I was able to get through everything, and I put the E500 in storage. This spring I got on with it again - slightly anxious as I had followed the great advice from here, and changed plugs, rotors, caps, plug wires - and also the insulator caps - but the misfire returned after a few days. I started fiddling with the vacuum hoses, and they were brittle, hence, I changed them. That was the last piece fo the puzzle. The car was transformed, now running beautifully, and with a real immediacy when pushing on. I decided to wait a while before reporting back, but the misfire has not returned. i have driven in rain several times, left the car outside in rain and damp for days. let it sit three weeks before using it again. It now starts and runs as it should every time. Let's hope it lasts! Will report if problems reoccur.
One thing, though: when replacing the oil pressure sensor I noticed that the wires below the car are brittle - the well known problem. Does anyone have advice on where to get a new lower wiring loom?
Re: 1995 E420 coughs stutters & backfires
Klink,
I remember you telling me about your theory that these insulators emit some sort of mysterious orange powder as they degrade and this powder can cause latent ignition problems. I went out to the garage and looked at an insulator I had replaced last year. This was from a car that spent its whole life in Southern California and had 200,000 miles on probably the original insulators. Sure enough, just rubbing the insulator with a shop towel caused some of that orange moon dust to come off (pic).
The first picture is the new insulator next to the old.
"moon dust", ha!
FWIW, the only place I see the insulators actually called insulators is here. Mercedes calls them "dust shields" which explains (at least to me) why so many mechanics overlook this ultra critical part of the ignition system in an M119. I just pulled and replaced them on my 500e and the originals actually had hairline cracks in them. The symptom was classic - car sits for a week or more, starts fine, then within a few minutes (or when shut off after a short run to the filling station) the engine either won't start or spits, farts, backfires and won't do anything more than idle. These parts are critical and much less expensive than another set of caps and rotors.
Hi, sorry to revive an old thread, but I´ve read it all and tried the suggested procedures without success. Car is a 1993 R129 with 119 engine and 722 trans. It has almost 8000 km on it and it´s in mint condition. The car have had this missfire a while ago and in the past, they´ve tried to solve it changing distributor rotors, caps, isolators, engine wiring harness, modules, coils, fuel pump, and the list of throwed parts goes on...
The engine behavior is erratic, like it has missfires on different cylinders and sometimes it just die. The idle quality is poor too. If I hit the gas pedal on a steady position (ie 4k rpm) for some brief moments in time, the engine runs perfect, but the missfire appears again and again, it´s kind of hard to explain in words, but think on it like having a 2-3 cylinder kill switch and toggle it on/off constantly. The isue is present on cold and hot engine but it gets a little worse when hot.
I´m not a mercedes expert and this platform is new to me. I´ve started getting the 38 pin diagnostic port codes with the test 3 pin cable tester I custom made for it, and after clearing it all, the following codes reappeared:
Pin 4 LH-SFI Codes 7 and 9 (7 is TNA-signal (rpm signal ) incorrect or open or short circuit, code 9 is starter related)
Pin 6 ABS Code 30 (it looks like a comms issue)
Pin 7 EA ISC CC Code 03, 07, 14 (it cleared after a few ignition cycles and code clearing process)
Pin 8 BM BAS Code 06 (Electromagnetic a/c compressor clutch blocked - Not Engine related)
Pin 17 DI TD TN Code 12 Tn-signal is outside the tolerance range
I have some other codes on the following systems, but I guess it´s not engine relevant.
I´ve tested the CPS resistance, around 850 cold and near 1k ohm hot. re-torqued it was little loose but no improvement on the described problem.
I´ve tested the Cam sensor, little above 1k ohm hot. I let it cool down but never saw it below 1k This sensor was changed, not OEM.
As you can see in the pictures, I´ve cleaned the distributor rotor caps and insulators on both sides. It had some moisture mainly on the rear part between the insulator and cam seal. The missfire stays the same.
I plan to take out the spark plugs. What if they´re not low resistance ones? Can it be the issue?
Also, there are 2 engine management codes related to RPM. Can it be the camshaft position sensor? Is there any other engine RPM related sensors on this engine?
What else should I look for?
Thanks in advance.
Used LH modules are fairly inexpensive. Even if it doesn’t fix your problem, if you are going to keep the car it is money well-spent. Is it the original Electronic Throttle Actuator and upper wiring harness?
My friend has another LH module to test and he did the swap before and told me the problem persist. I´ve not made the test myself to be honest.
Wiring harness was changed like a year ago.
Do not overlook simple things like every vacuum hose in the engine bay, and the rubber used to connect them. ME - Get 10m of hose and just replace all of it and use new connectors (I prefer the high temp silicone variety in bulk cut to fit) There are two Pierburg valves on the PS fender, and one near the brake booster. The EZL line to the back of the intake is a common broken line (ask me, I just replaced) and of the course another hot exposure one is the intake to the transmission modulation valve. Smoke test would probably be useless at this point if you just change them all to a known quantity perfect. It would show that by now most of us will need to pull intake and replace the donuts there as they are going to crack and leak just by looking at them if original. :D Luckily there is a great HOW-TO INTAKE thread by member GVZ who did this for us with great insights and pics.
Ouch. Most of those parts should not have needed replacement with only 8000 km's. 😟
Does the engine ever run smoothly on all 8 cylinders? Have the fuel injectors been tested / cleaned? With only 8kkm in 30 years, the car may have had stale fuel for years at a time.
See notes below:
Pin 4 LH-SFI Codes 7 (TN-signal / rpm signal - incorrect or open/short circuit)
This is an odd / unusual fault code. If this keeps recurring, something may be up with the RPM signal.​
Pin 4 LH-SFI Codes 9 (Starter signal (circuit 50) missing, open/short circuit)
Yet another odd fault code. See if this recurs after being cleared.​
Pin 6 ABS Code 30 (CAN data bus to E-GAS control module (N4/1), interrupted)
This is a "ghost code", it can typically be ignored. This code will appear any time "limp mode" occurs. Note that limp mode will be triggered if you operate the throttle linkage behind the airbox! Do not try to rev the engine from the linkage behind the airbox, this will trigger limp mode every time and store erroneous fault codes.​
Pin 7 EA ISC CC Code 03 (Various faults related to ETA / throttle actuator)
Pin 7 EA ISC CC Code 07 (CAN databus: messages faulty)
Pin 7 EA ISC CC Code 14 (Closed throttle position switch (S29/3)
See if any of these code return after you have cleared them. You may have a faulty ETA, the wiring may be disintegrating.​
Pin 8 BM BAS Code 06 (A/C electromagnetic clutch (A9k1) jammed or poly-V-belt broken.)
This code occurs when the RPM signals do not match between engine and AC compressor. It could be related to the TN/RPM signal fault.​
Pin 17 DI / EZL Code 12 (TN-signal (engine rpm output) is outside of tolerance range)
This is another odd fault code.​
Sounds normal. The crank sensor is original / OE, correct? It should be fine, I would not replace it.
I'd re-install the original / OE cam position sensor (if available), the aftermarket ones are all Chinese. This is very unlikely to be causing your problems though.
There is some light carbon-tracking visible on the caps, indicating a misfire of some sort. You should also add additional vent slots into the new caps as described in this thread. I also see a trace of engine oil at the lower edge of both caps, but I don't think that's the root cause of what you are currently dealing with.
Unless the plugs are physically damaged or otherwise faulty, no, this should not cause the problem. The "wrong" spec plugs would not cause this type of misfiring. However, you should verify they are correct non-resistor F8DC4 or equivalent, and set the gap to 1.0mm (larger than spec of 0.8mm). Verify there is no engine oil leaking from the valve cover gasket into the plug wells. Oil on the threads is normal but there should not be oil on the hex flats or insulator. Also see if the spark plugs have a normal light brown / tan color on the insulator. The insulator should not be black or oily. And, all 8 plugs should look similar.
ALSO, measure each spark plug boot for resistance, normal is 1600-2400 ohms... if any measure significantly higher (say, 5k-10k ohms or more) that boot is faulty. You can look for arcing under the hood at night, if any wires are arcing to ground, replace the wire set (with Beru, details here). Don't replace the wires unless you confirm they are faulty.
This is very unusual, and if these codes keep returning after you clear them, you need to investigate further until you can correct this problem. This is NOT related to the camshaft position sensor. The engine RPM signal is from the crankshaft sensor, located below the driver side cylinder head (behind cyl #8), on the upper transmission bellhousing area. The crank sensor (CKP) connects to the EZL. There are 2 magnets on the flywheel which trigger the sensor.
1) After clearing all of the codes above, and driving the car, which codes appear after the misfire occurs? Codes do not clear on their own, if never checked, some codes could be from many years ago and irrelevant to your current faults.
2) Has the transmission ever been removed from this car, and was ANY work done just before the misfiring problems began?
3) Take a photo of the EZL part number, and remove the CAN box and take a photo of the modules in the CAN box (especially LH and E-GAS). We need to verify all those part numbers are correct.
4) For grins, try disconnecting the MAF and see if the engine runs the same, better, or worse. If it runs better, your MAF could be defective. I really doubt it, but this is an easy test.
5) For more detailed diagnostics you really need live data (see the video in this post). If you can view live data while the misfire is occurring, it will identify the exact cylinders which are at fault, which may help point you in the right direction. You can also verify the MAF airflow readings are accurate, and verify the LH adaptation values are not near maximum (indicating a mixture issue). Do you know anyone that could connect SDS with HHT-Win to your car, to view the live data? Alternately, you can buy this for ~$600 USD or so, it will work on most all Mercedes from early 90's and newer.
6) What brand distributor caps & rotors were installed? It's possible to have defective new parts out of the box... this is rare, but it's happened to more than one forum member over the years. This would not cause the TN/RPM fault code though.
7) If you keep getting the ETA-related faults on the E-GAS module, your ETA may need a rebuild (the internal wiring can have the insulation fall off). I wouldn't replace the ETA, the internal pots/switches/clutch should be brand new (8kkm!), only the wiring needs to be repaired.
Totally agreed. The worst part is, whole old OEM parts were thrown on trash...
Yes, for about 1 or 2 seconds with the gas pedal applied on various RPM ranges and even at idle. My friend said the injectors were cleaned/tested, fuel tank cleaned and fuel pump changed twice. I have my doubts on the injector cleaning...
Will double check on the sensor brand. I didn´t take it out, just re torque it and measured the resistance on the connector end.
Whole old sensors and parts were dumped...
Totally agreed and will do the added vents. I´m also thinking this is not the root cause. I´ve cleaned the caps, rotors and insulators and the missfire was the same. Also saw some orange/oily substance when cleaning the parts. Insulators had moisture on the back and little moisture inside the caps.
Will check each spark plug wire and spark plug.
The car is not drivable right now. The missfire is heavy and also sometimes the engine just die.
This was my first question to the owner, but the answer was "no". Just a self started missfire.
I think you meant the box that contains whole modules near the 38ping diagnosting port, right? Will do.
Wil do.
I don´t see any brand on the caps. I´ve seen the MB logo on the insulators so my guessing is, it wasn´t changed.
Nice tip. I´ll double check it. Any related post on the rebuild will be appreciated.
Thanks!
