For those of you who have been experiencing intermittent engine stalling and misfiring issues, I think I have the smoking gun . My issue was my car would start up and run fine . As it would reach Op temp, it would hiccup occasionally , but still run fine. As I proceeded it would eventually stall. Wouldn’t matter if I was driving it or performing this experiment in my garage . The culprit WAS NOT primarily the RED insulator caps which would shows some condensation. The problem was actually the Distributor Caps/ Rotors. I’d been chasing this issue for years . So although the Caps, Rotors / insulators were “ new” the problem still returned . BOSCH = BAD for M119. BREMI = GOOD.
Bosch and manufacturers who follow their Rotor / DC design have a limited electrode surface area and will corrode particularly in high humidity areas.(Houston) BREMI has a design that has a much larger electrode surface contact area. Therefore the spark can find multiple areas to arc and stays cleaner longer ...
The first cap is the BREMI. You can see that the 4 peripheral electrodes are almost completely exposed , Whereas the Bosch design shows just the face of the electrode and the rest is covered in the mold.
