M119 REBUILD TO E60
faltinor
Hi,
I originally started with a simple engine oil change, but things got really messy once we opened the oil sump. Thank God we decided to do this engine service—otherwise the engine would have broken down very soon. At this point, a full rebuild is necessary.
Just to give some context, the car has 250,000 km on it. I’ll be going through everything that needs to be replaced. Honestly, we removed a lot of parts that make you wonder how this car was still running without showing any problems at all.
These cars don’t usually show clear signs of wear or fatigue, but after 34 years, many components inevitably need attention. The car is from Japan with American-spec and was very well looked after, but until you remove the differential, gearbox, and engine, you don’t realize how much the wiring harness has deteriorated.
Plastics in the differential, mounts, and many other parts need to be replaced. Believe me, there’s a lot going on—I’ll be sharing some photos to show what we found.
My goal is to rebuild the engine properly and reliably, not just refresh it. Depending on feasibility and parts availability, I am considering either:
  • A strong OEM+ rebuild, or
  • A performance-oriented rebuild (possibly increased displacement)
I’m planning to convert the M119 5.0 to a proper 6.0 build. Since the block is Alusil and damaged, the plan is to sleeve all 8 cylinders and rebuild it correctly for long-term reliability.
Planned setup:
  • Ductile iron sleeves (8 cylinders)
  • Stroker crank
  • Custom forged pistons (≈100.0–100.5 mm)
  • Forged rods
  • Balanced rotating assembly
Looking for advice from anyone who has done an M119 6.0 build, especially on:
  • Crank stroke & final displacement
  • Piston specs (brand, compression, ring pack)
  • Rod length / rod ratio
  • Camshaft options
  • Harmonic balancer
  • Head gasket solutions & clearances
Any real-world experience, part numbers, or recommendations would be greatly appreciated.
Thanks in advance.
The car is from Japan with American-spec ...
Engine #3594 is from chassis WDB1240361B729614, which was a German-delivered, Euro-spec car that should have the oil cooler and all the usual Euro goodies (E/S switch, etc).
Swapping in a good, used M119.97x engine would be the easiest & cheapest solution. M119's rarely need a full rebuild, you were extraordinarily unlucky with this one. Most of the time all they need is an external reseal, although new valve stem seals would be a good idea, and new head gaskets wouldn't hurt. I'd leave the bottom end alone.
Increased displacement will be a very expensive option. Likely tens of thousands of dollars to do it properly. There isn't much you can do to increase power with stock displacement though. A stroker crank with stock bore would net you 5.6L displacement, but still requires custom pistons, and replacing the cracked block. @Klink, @jhodg5ck - have you ever seen a block cracked like this, at the top of the bore?
Planned setup:
Why sleeve the block with iron? Is it because of the cracked cylinders? Why not replace the block and bore to 100mm with Alusil, since 5.0L M119 blocks are cheap and plentiful?
Most of this information is covered in the E60 AMG factory document here. Copy/paste text or images into Google translate as needed.
  • Camshaft options
Sourcing camshafts will be difficult. Cheapest option is to use the early (1990-1992) 5.0L LH camshafts, which are present on your disassembled engine. Later cams had reduced lift and single valve springs. Another option is sourcing regrinds from Dbilas or Hagmann, or full custom camshafts. The power gain may be modest vs the high cost though. Depends what your budget is. Blue Ridge MB was investigating having custom camshafts produced but I don't think they are available yet, and they won't be cheap.
  • Harmonic balancer
AFAIK the stock balancer is used. You may need custom head gaskets if the OE AMG gaskets are NLA. The AMG gaskets are something like €3k / pair.
You'll need a 6.0L LH module to match the displacement. There's one for sale here if you need it. If building a 5.6L, a custom program will be required.
:blower:
:blower:
Thank you for the quick and detailed reply, I really appreciate it.
I agree that sourcing another good block is likely the best long-term solution. In many ways, starting with a healthy block feels similar to beginning with a zero-kilometer engine, which gives much more confidence from a reliability standpoint.
My intention is not just to make the engine run again, but to rebuild it properly for long-term ownership. I believe that starting from a solid foundation will preserve both the driving enjoyment and the car’s value going forward, especially considering the mileage from this point on.
Thanks again for taking the time to share your experience and insights — it’s very helpful.
Would it make more sense to purchase an R129 SL500 with a well-documented engine service history, so I could use it as a donor later on — not only for the engine, but also for other components such as the brakes?
The early 129.067 500SL or SL500 with M119.972 engine would mostly just provide a good engine. The front 129.067 brakes are the same size as stock early 500E (300x22), in iron Ate only. The rear 129 brakes are smaller (thinner, non-vented) on the R129. Nothing of value there, and the differential won't swap either. The computer modules all work, but that's about it. Usually it's not worth buying a complete SL500 unless it's really cheap. Make sure you don't buy a later 129.067 with the 119.98x engine... those are completely different.
If you want to bore the block to 100mm, it also must be an early production car with closed-deck block. I forget the exact production break but it was approximately late 1993. By 1994, I think all M119 engines were open-deck. The casting number on the side of the block will confirm open deck vs closed deck. Open-deck blocks do not support boring to 100mm.
:nos:
I’ll update you tomorrow after speaking with my mechanic. He has over 35 years of experience building race engines. He already has a few ideas in mind, but wants to properly inspect everything first. He has successfully applied similar solutions many times on long-life rally engines. I’ll share an update once we’ve reviewed it together.
99% of the time, iron sleeves are used because not many machine shops are set up to bore & etch Alusil blocks. However, the Alusil block is more robust and long-lasting vs iron. So there is some tradeoff. And, you pray the sleeve never moves... that's another risk. You still need custom pistons either way, but I guess custom pistons for iron sleeves are probably more common vs coated properly for Alusil.
More info on Alusil block boring / etching is in this document.
:v8:
Hi,
Planned setup:
  • Stroker crank
  • Forged rods
  • Camshaft options
  • Harmonic balancer
Thanks in advance.
Hi everyone,
After many months, my 1992 500E (M119.974) rebuild is finally underway.
The block has been inspected, machined and three damaged cylinders have been fitted with dry steel sleeves. The remaining bores are still within specification, but before going any further I’d really appreciate advice from those who have rebuilt these engines.
Current issue
We cannot find the correct OEM piston ring set.
We ordered Goetze 08-182700-00 (96.5 mm) through Trodo, but the rings supplied are not the same as my originals. They are thicker and won’t fit my pistons.
My questions
  1. What is the correct piston ring set or Mercedes part number for the M119.974?
  2. Where can I buy genuine or correct-quality rings? (Mercedes, Mahle, Goetze, Kolbenschmidt, etc.)
  3. Has anyone else received the wrong Goetze ring set?
Since the engine is completely apart…
  1. Would you sleeve only the three damaged cylinders, or all eight for long-term reliability and consistent bore dimensions?
  2. What piston ring end gaps do you recommend?
    • Top ring
    • Second ring
    • Oil ring rails
  3. Are the factory specifications still the best choice, or would you recommend slightly different gaps for a rebuilt street engine?
  4. What piston-to-wall clearance would you use with steel sleeves?
  5. Would you plateau hone the sleeves, and if so, what final hone finish (RA/RVK or grit) works best with OEM-style rings?
  6. Anything else you would replace while the block is apart that is commonly overlooked on M119 rebuilds?
I’m aiming for a factory-reliable engine, not a race engine. I already have new bearings, timing components and the rest of the rebuild parts.
Any advice from members who have built several M119s would be greatly appreciated.
Thank you!
Early and late M119 engines have different piston rings. Later engines have thinner rings, IIRC? The change was approximately around mid-1992 production. You'll need to figure out if you have the early or late style. Sorry, I can't help much beyond this. The FSM (factory service manual) may have details. I assume you are using the FSM for this work - if not, it is absolutely required.
AFAIK the bores should not be honed, they are supposed to be etched? Alusil blocks require special treatment. Make sure the shop knows Alusil intimately.
:wormhole:
Aluminum cylinders require the Alysil treatment but what about the 3 steel sleeved cylinders? I’m not sure this combo will work together. Wouldn’t a another all aluminum block be a better solution?
Just thinking out loud.:)
I missed the steel sleeves. WHY did they do that? You will need completely different pistons & rings for those 3 cylinders!! :facepalm: :doh:
Terry is right. Buy a good used engine. They are cheap in USA, not sure about where you live, but may still be cheaper to buy one from another country and have it shipped in.
Thank you. This is exactly what I am concerned about now.
The shop installed three steel liners because those cylinders were damaged, but no final machining or assembly has been completed yet. We are still using the original pistons and are trying to identify the correct M119.974 piston rings.
Before continuing, I will ask the machine shop for the exact liner material, finished bore dimensions, piston-to-wall clearances and the proposed ring material/coating. I also want confirmation from a piston or ring manufacturer that one ring package can safely work with three steel-lined bores and five original Alusil bores.
If this combination cannot be properly validated, I agree that a good original M119.974 block or complete engine may be the safer solution.
Alternatively, would sleeving all eight cylinders with matched pistons and rings be technically acceptable if performed by a specialist?
For now, I will not allow final honing or assembly until this is clarified.
Hi everyone,
We’re currently rebuilding an M119.974 engine and I’d appreciate some advice from those who have rebuilt one before.
The block has already been fitted with three steel sleeves, and we’re now trying to source the correct piston ring set.
We ordered a Goetze 08-182700-00 ring set. The dimensions are correct (96.5 mm, 1.75 / 2.0 / 3.5 mm STD), but when we compared them with the original Mercedes rings, they are clearly different.
The original Mercedes ring set appears to be an all-steel design, while the Goetze rings have a different construction/material. Although the dimensions are identical, they don’t look or feel like the original rings.
My questions are:
  1. Has anyone successfully used these Goetze rings on an M119.974, or should I continue searching for the genuine Mercedes all-steel ring set?
  2. Since the engine now has three steel sleeves, would you recommend sleeving all eight cylinders for consistency, or is it perfectly acceptable to leave the remaining five as Alusil?
  3. What piston ring end gaps would you recommend for a sleeved M119.974? Should the factory specifications still be used, or do they need to be adjusted?
Any advice or experience with rebuilding these engines would be greatly appreciated.
Thanks in advance!
Forgot to mention. No, I would not sleeve all 8 bores. I do not understand why some machine shops are so sleeve-happy with iron/steel sleeves in an Alusil block. This eliminates all the benefits of Alusil. Normally, Alusil blocks last the life of the car. There's an owner on this forum with a car that has over 1 million km's on the original E500 engine, never rebuilt. This is also why used engines are a good alternative - if the bores are good and the internals do not have excessive sludge, the used engine is likely as good as "new" after replacing external seals to prevent leaks.
Part of the reason it is so difficult to obtain piston rings & pistons, is because nobody ever rebuilds these engines... because there is no need to.
:peep:
:peep:
Hi,
If the original piston rings are no longer available, what ring set would you recommend for three sleeved cylinders and five original Alusil cylinders? Would you run two different ring types in the same engine, or is there another solution?
At this point, I would contact piston ring specialty manufacturers to inquire if they could custom-fabricate a ring that will work for this application. I have no idea if it's possible, or what the cost is, but that would be my next step if it were my engine.
Disclaimer: This is out of my area of expertise, and I would strongly recommend contact piston/ring mfr's to see what they have to say. I'd probably start with Mahle and Kolbenschmidt for grins, although I expect neither may be able to help.
Hi,
Try Total Seal USA, custom piston rings.
You will need to send a piston to them as well.
