WANTED MAF M119 E420 1993
mb_love
After reading fail codes realized I want to test with a new MAF.
Hopefully in Europe but interested anyhow I can get my car running fine and through inspection.
The car has been standing in cold storage for many years before I bought it but it’s a dream to drive 🙂
004 Air mass sensor Volt. to large small.
Air mass hot wire = 3.9 kg/h.
Voltage to MAF was in spec.
Also in limp mode. ASR, ABS does not answer.
Thank you 🙏 Looking every day. I was out looking yesterday and nothing in Sweden maybe one but they are on vacation this week.
I do have one available for sale. It is a used Bosch 0 280 214 004 bought from a forum member many years ago. Send me a private message and we can work on details if you still need one.
Thank you @timpurister after replacing with your MAF that fail code is gone!! 🙏
Had to replace ASR unit to get that system reachable and working. Also from Finland 💪
Hopefully my only problem now is the alternator..
Battery (new) voltage is reading 13.2V, with ignition on 12.9V and at idle 12.7V
When I rev battery, ABS and ASR light goes away!
Recently made a new lower engine harness so that should not be the problem.
I’m searching for a 009 154 1902 alternator now.
Looked a bit tricky to remove any threads on what’s easiest?
Cool that you are making progress with the trouble shooting
Search for „alternator how to“ and you will find plenty of good info such as this awesome write up from derfuror
:searchdammit:
That's a bad voltage regulator and/or alternator. Removing the alternator may be more difficult on European-spec models with the engine oil cooler, the plumbing may be in the way. You might need to remove the fan+clutch, and/or sway bar, for additional acccess. I'm not sure though.
:sawzall:
:sawzall:
Thanks yes maybe that is the two options but looked tight not like my older car 😅 Probably easiest to remove radiator.
