SOLD Magnaflow #23581 49-state catalytic converter pipe for 034/036
gsxr
This is Magnaflow #23581, a 49-state pipe that will fit all years of W124 500E/E500 and 400E/E420. Click here for Magnaflow website specs, ignore the mention of fitting 400SEL. :rolleyes: (Edit - new link here.)
This pipe came on a car I purchased, installed by the previous owner, who found the 2 sections did not fit together as delivered from Magnaflow. He notched the pipes to make them fit together, but they will not stay in place. Vibration from driving causes the 2 pieces to slide apart over time. I eventually gave up messing with it and swapped on a used factory catalyst pipe I had from a parts car.
These cats were only used for about 1000 miles and are in excellent condition except for the notches at the center connection. The cats are NOT CARB compliant and will not pass California emissions visual inspection. As seen in the photos, cutting and/or welding will be required to provide a leak-free connection. The pipe is manufactured in 2 pieces to reduce shipping size, and could be welded together after quadruple checking the position/fitment is correct. Again, this will not be a simple plug+play installation, you either need welding skillz or need to have an exhaust shop install them. It may be easier to cut off the notched portions and weld something else on that would be a clean slip-fit. I can't weld so I was unable to do anything with them.
Anyway - this setup is $885 $1060 list, and typically sells for $750-$800 $750-$1000 new. Factory/dealer MB cats are NLA. Shipping will be expensive, around $50-$100 USD, due to the very large box size. PM me your zipcode for a ship quote. Free local pickup.
International shipment is not possible due to the size/weight, but I can send to a freight forwarder within USA.
:update:
Decided to keep this after seeing the price has gone over $1000 and there was no interest at less than half that much.
Did you or the previous owner ever have the notched parts welded?? simply stuck together?? I can't see where there are mods to cats themselves...these need to be turned a bit to fit side-by-side I thought....
They were never welded, only notched and clamped. No modifications to the catalysts, just the couple inches notched at each pipe joint.
I've read about someone else who found that this same Magnaflow new, out-of-the-box, would not slip-fit together. I can't remember what the other person did. It was a forum member I think.
:sawzall:
Sorry to beat you up w questions...just nearing the end of my to-do's (and budget) on this beast. Was this actually mounted to a 500 (yours or previous) to know for certain that it fits? I know Magnaflow thinks they do but had my car on the rack the other day and doesn't look like they'll fit in parallel without turning.
Yup, it was on one of my 500's. It does fit properly other than the 2 pieces not connecting together nicely. Unfortunately I don't think I have any photos of it installed.
:oops:
bonjour, je souhaite acheter vos échappement je suis en France , quel serait les frais de transport pour la France , merci pour votre service ! cordialement Franck
