I’m replacing my brake fluid reservoir, and the supposedly correct part doesn’t seem to be compatible. I can tell it’s an updated ATE part instead of the original Girling, but the EPC says this part number is correct:
002 430 11 02
The issue is that the fitting for the braided ASR hose on the bottom of the new reservoir is completely missing. It seems like it was permanently filled in when it was produced. There’s a protruding tube which is capped off on the OPPOSITE end, but doesn’t seem designed to be removed. The only two connection points seem to be where the two main rubber grommets sit. The whole reservoir also seems slightly larger than the original part. You can see everything in the pictures attached. It appears that it would work fine other than this issue, and I haven’t found any alternative part numbers that are different to this exact part. Here’s the link to it on FCP, where it says the part will fit:
002 430 11 02
Mercedes Brake Master Cylinder Reservoir - Genuine Mercedes 0004301102
www.fcpeuro.com
