Hi,
Currently in the middle of complete reseal of the steering gear because of a leaking input shaft seal and I've ran into an issue.
As the FSM states the seal for bearing cover is different in 124.034/036 and 140 models. However I can't find a part number for the spesific seal. I ordered individually all the seals from the complete seal kit. There is also other issues when comparing schematics from epc to the actual steering gear and FSM. For example couldn't find a place for seal 44. 47 is either the o-ring for bearing cover (16 in FSM) which should be replaced with a sealing washer in 124.036 or o-ring in steering housing(81 in FSM). Also input shaft seal is drawn as an o-ring number 29 instead of radial shaft seal.
Even ordered a seal kit for 140 and the seal looks identical but is larger in diameter.
So any help is greatly apreciated in search of the correct seal. I find it unlikely that companies that rebuild these gearboxes would reuse this seal so it should be available or there is some sort of replacement.
Emppu
Emppu
