Developed a pop noise in front right..possibly towards center, hard to tell. Isnt
frequent... initially felt when making a right turn onto a downward dip street from the right front. Initially suspected chassis brace bars needing retightened. That did not fix.
Inspected front end. Idler bushing had some decent up and down play. Replaced and torqued properly OEM.
Strut tower mounts show no cracking even when wheels clocked completely in either direction.
Struts are all new bilstien.
Jacked up control arm and pried at wheel. No play.
No tie rod play rocking in air.
Replaced sway bar end bushings OEM.
Bearing do need to be adjusted here shortly.
Car has 65k. Recently acquired.
Pop noise seems to shift...as in if I get it to pop turning hard right (above 15mph at a 90* turn) and then come to a light and make a left turn, it will pop in that location again. As if load is shifting something. Sound seems to be like chassis brace or a worn tie rod but makes zero noise in high speed 45* turns, slow 90* turns, or turning stationary...or over bumps.
Aside from this and needing motor mounts, car is rock solid
Any thoughts?
Any thoughts?
