Rear subframe grommet P/N?
jnes
Does anybody have part number for that grommet? Wires are rear brake wear indicator. I tried to search from EPC but no luck so far. Pics attached.
I had it on hand as im in the middle of subframe rebuild and theres No part number on the grommet. As im here i would like to ask if anybody knows the part number for those 3 clips that hold the brake wear indicator cable (visible on first pic at the bottom edge of the rear subframe rail). I took a pic of one of those but it got lost and i can not find them in epc as well.
Edit:
Ok i found the clip on WDB140050 VIN number in category 32, diagram 400 and the part number is A 129 546 02 43 but it does not show in the same place for 124036 like its not meant to be on W124. The price is also quite high like for a plastic clip :blink:
You are correct - the plastic clip is p/n 129-546-02-43, and the price has more than doubled from a few years ago. It's currently $10.50 each MSRP in USA. Ouch! 3 clips required for 124's with ASR.
I could not find the round rubber grommet in the EPC for the 124.036 chassis.
:runexe:
