Hi guys
I have strange situation with my transmission. First thing is that i can not drop it to first gear no matter what.
Putting it in D or 3 results start normally in 2'nd speed but full throttle + kickdown switch will not give me 1st gear. However i found that when i put selector lever in 2 then even half throttle will give me 1 st gear start easily. I checked kickdown switch and b-switch and both give +12V on kickdown solenoid plug if pressed. Bowden cable checked and is adjusted as should.
Recently I took VB off to change K1 spring kit and then this started. Could wrongly inserted selector lever in VB couse this? I need to drop pan and check this but maybe someone have a theory what else to check and what to look for. Before transmission worked fine so its definitly something with VB but what??
