O2-sensor defective?
little_e
Dag
I did a live readout with HFM-scan in my 1993 500E.
When the engine is idling or I’m driving and depress the accelerator, the
appears:
50% O2S 1 (before TWC) (G3/2) not operational or defective, open circuit
The O2-sensor was swapped one year ago with an OEM part.
Why does this only appear when the engine is idling?
Is the sensor really faulty?
If there are no stored fault codes, it may be a glitch with HFM Scan software. I'd compare to live data from a scanner designed for LH (SDS, MT2500, etc).
appears:
The live reading must constantly fluctuate around the 50% mark (48-52%) and not just read 50%
appears:
Double-check that the sensor connector is firmly & securely connected. A loose connection can cause the open circuit condition.
