Outside temp sensor replacement?
Post number 9 has been selected as best answered.
Glen
Site Admin, auto enthusiast...
Has anyone replaced the outside temp sensor? The one mounted in the front bumper. Recently, the LCD panel was reading high (110F in 50F temps) so I replaced the LCD with a used one. Now it's reading 132F, LOL. I tested both the original and replacement panels in another W124 and confirmed the original is bad, reading low by 11F. The replacement is displaying correctly so it must either be the bumper sensor or wiring. My main question, is where does the external sensor terminate? Fuse box or behind the dash?
Thanks!
Glen, it terminates in the fuse box. The wire routes along the fender by the EZL after passing by the coils, aux fan resistor, etc.
There's a spec in FSM for various temps / resistances if you want to check the sensor with a meter before replacing. I've found the LCD's are rarely more than ±1° off when bench tested.
:bbq:
I just measured and got fluctuations between 950 and 1100 ohms at ~62F. I think this corresponds to the 132F to 136F I see on the display. Prognosis: bad sensor.
Thanks Dave!
You can replace the thermistor at the front for less than $1 and save yourself a hassle of rerouting the wires. You need 3.3KOhm NTC thermistor, buy 5 of them. Test them one by one it should be as close as possible to 3.3KOhm in 20 degrees Celsius (68 degrees Fahrenheit).
It is just the mater of cutting the wire as close to the metal housing as possible, drilling old hot glue, soldering new thermistor and hot gluing it back in to the metal housing.
Did 3 times already, all of them work perfectly.
Just want to close off this thread. I picked up a used sensor from a local salvage yard and spliced in a water proof connector. Temp is now reading correctly.
That's a great writeup, Dan. And coincidentally, it looks like it's finally time to put the thermocouple you sent me into service.
