We had the instrument cluster out of my 1992 500E, as noted in the thread on it not running right, and we noted that the gears were stripped and replaced them. Today I trialed the car and although it ran fine, the odo and trip meters still aren't working. So, a few questions:
I have the impression that the way they work is that there is a small motor that turns the gears; there is no direct mechanical drive to the cluster. My guess is that there is a variable speed motor governed by the speed of the car, which in turn turns the odo/trip gear train. Any information on this would be helpful. I suspect perhaps the motor is burnt out, or not turning for some other reason. (when we reassembled the cluster, we verified that all the little gears were working fine)
Also, are all 124 instrument clusters similar- that is, could I find a good used cluster, from a 300E or 400E,set it to the same mileage, and install it? Or are not all 124 instrument clusters alike?
Thanks as always, for any help! Jim R
