Original or Remanufactured Alternator
emerydc8
Does anyone know how to tell if this alternator has been re-manufactured based on the sticker?
I'll have to look at mine from 2011. That could be an older reman
But most reman Bosch decals look like this............
Doesn't have the remain p/n. I though the bosch factory parts have both the factory p/n and bosch #?
Michael
As far as I'm concerned, it's an older remanufactured unit.
I don't recall seeing any decal on the alternators when the cars were new.
My original alternator did not have one.
Does it matter?
How many miles are on the car? If your going to pull it out, the regulator should have a date code on it.
I would take the fan belt loose and check to see if the bearings are good at a minimum if you are concerned.
Or just get rid of the stocker- 143 or 150A is the way to go!
Michael
I have 200,000 miles on the car. So I'm hoping the alternator was already replaced by a prior owner. There is no indication that it is about to fail.
