here you go I have two parts numbers for you..as i am abit unsure..cause the bracket that SEEMS to be(from looking at the location of the part ON the EPC film) the one you need...does remind me of the bracket that holds the brake wear indicator wiring across the subframe (where the diff cover sits against)
So it is either this one(which on the EPC, looks like the bracket for the wiring that runs across the rear side of the rear subframe,meaning the incorrect bracket you are looking for..but the picture on the EPC can be misleading..so i post it anyways,and also ,here is a picture of the bracket i talk about..it is NLA..so i had to make myself a new one on my car )
Bracket: A1245422140
OR this one..which is a bracket bolted on the subframe on the "same" location as the one you have circled,so i really think THIS is the correct PN
Bracket : A1245422240
Nut rail to bracket : N913023006001
anyways..it SHOULD be either one of these.I hope it helps you out
Old topic but I'm about to reproduce this part and have it yellow plated as original one. It is quite common that this part is rusted or either bad condition. Of course this is only visible for MOT guy and function of the part is only to carry wiring to the brake pad wearing indicator.
My plan is to make exact copy of this. I'll post photos when I receive my part from the manufacturer. What comes to cost at the moment I have no idea. I'll let you know.
