@Ricardo, the purge valve can be bypassed if desired. It will not affect engine operation. The tank still vents into the canister, and the canister doesn't need replacement if the valve is bypassed. So, you can disable the purge system - for off-road/racing use only, of course. OTOH, if you keep the purge system intact, a new canister is probably a good idea - seems quite a few have ruptured screens/mesh/whatever that is supposed to keep the carbon from sneaking out under vacuum.
