misfiring and poping sound
How old are the distributor caps / rotors, and have you removed them to check for moisture when the misfire occurs? And, have you added more ventilation slots in the caps to help with the moisture issue?
More info here:
:sawzall:
i cleaned them they worked ok for 6months
Yeah, you'll need to do more diagnosis. If there's an oil leak in that area - including just a trace of oil at the bottom edge of the cap - this may cause problems.
In the meantime, clean & dry them again, but this time add the vent slots as shown in the thread linked above.
:mushroom:
Did it just start acting like this out of the blue? Like Dave said, I would check the caps and rotors but it sounds like maybe you have a failure of one of the ignition components (rotor?).
I once inadvertently crossed plug wires after changing rotors and caps and it acted like this. You pointed to the driver's side bank and said it was #3 or #4 that's misfiring. Numbers 3 and 4 are on the passenger side. It goes from the piston closest to the driver is the highest (#8), then forward on the bank to numbers 7, 6, and 5. The piston closest to the passenger is #4 and forward from that is 3, 2 and 1. Hopefully it's something that simple. BTDT.
Attached is a crude drawing that helps when installing plug wires.
Last year a Bosch cap or rotor got progressively worse on me over a one-month period until it seemed to be running on four cylinders. Since I had a new set on the shelf I replaced both caps and rotors. The insulators were good. That completely fixed the problem. I still don’t know what failed. I saved the old parts.
bro my caps are the one that came with the car from 1995
uh... well... might be time to start there. Can you post photos of the insides of the caps on the car now?
Cut additional vent slots in the new caps. New rotors would be a good idea only. Genuine / OE, or Bosch only. Not Bremi, not Facet.
Just curious: do you see any hairline cracks in the caps, maybe looking with a magnifying glass? Here are the bad caps/rotors that caused problems for me. It started out as a gradual misfire and by the time I decided to install new caps and rotors it felt like it was running on four cylinders. I still don't know why the new parts did the trick. All I can see are tiny hairline cracks on each cap. Whether that caused the problem I don't know. If those really are original caps and rotors on your car then you should change them even if they're not causing your problem. Buy them before they stop making them because I think that day is coming.
