Hi folks,
I have read a lot about graduating from blink code readers to digital scanners. May I ask - what am I looking for? I check out ebay and I see “star c5” or “star c6” from China that comes with a naked hard drive. Are you supposed to build a PC with that hard drive or something? Also I read the the Chinese knockoffs have some incompatibility issue?
The various threads I see all reference “mt2500” or “HHT-Win” or “STAR SDS” or “C3 C4” and, not knowing what the whole system is supposed to look like, I am kind of lost. Any guidance for a plug and play solution is appreciated since I do not know what I am doing. Thanks. Snippets below for reference:
Not a scope, a Mercedes-specific digital scanner that will show actual values / live data from the computer modules. Specifically, the Star Diagnostics / SDS, either C3 or C4, with HHT-Win support.
Definitely try unplugging the MAF and see what happens! This is easy and free.
For a digital scanner, SDS (C3 or C4) with HHT-Win support is the only viable option. On the bright side that will work on all MB's through present day, or whatever date the software is anyway. It MUST have HHT-Win support for the 1990's cars though; be careful when shopping.
Does the car run & drive normally? Are you certain the tachometer is accurately reading 1000rpm at hot idle?
Idle speed is controlled by the E-GAS module and ETA. Temp sensors should not cause this behavior.
You really need live data from a digital scanner (HHT-Win on SDS) for further diagnostics, assuming no fault codes are stored.
