R129 m119 lower engine harness
Dmisem
New Member
Dear forum, could you please guide me where to find the pinout/wiring diagram for m119 on r129 1993? I took mine out - it’s completely rotten/desintegrated, need to build new one . Thanks a lot.
Thank you very much for the advice. I had no problems removing the harness. Just need the pinout to confirm the correct wiring.
This is for the W124 upper harness, but the R129 should be similar.
EDIT: ooops, OP wanted the lower harness! :doof:
Thank you, any chance you have the same for the lower harness? I have the top one fixed already.
Why would you need this for the lower harness? There are only 4 wires besides the main battery cable.
Schematics for the W124 are in the FSM here, look at the LH-SFI schematics. Not sure what the R129 is like and there is no PDF service manual for R129 that I know of.
thanks. I just would like to make sure that 4 are in a correct order.
Take a photo of the wire locations before removing them from the connector. Hopefully you haven't already taken it apart...
:hide1:
I already re-soldered everything. just want to make sure before installing it back. may be you know where to get the ECU schematics? thanks
ECU schematics are at the link in post #6 (link fixed now, ooops).
:jelmerian:
