That sounds like full retail - yikes. For ease of purchase, you might want to just get the loaded kit (which includes the crossovers). Remember if you get the Jehnert loaded setup, your amp should be 2-ohm stable, as they parallel the twin door woofers (4 ohm each, 2 ohm load to the amp). This kit likes power, so if you were going to run an amp bridged, that could be a problem... many amps on the market today are
not 2-ohm rated in bridged mode.
That said... if you haven't seen this thread yet, check it out. This ERASE guy went seriously bonkers with his Jehnert install, after being disappointed with the Rainbows (mentioned in post 1):
http://www.benzworld.org/forums/w12...87-erases-determined-w124-stereo-journey.html
I would love to try those Scan Speak 12M drivers in the dash, but eeek, they are not cheap. See posts 10 and 15 at the link above, he says they fit perfect in the 124 dash:
http://meniscusaudio.com/scan-speak-12m4631g-p-465.html
Note that I believe he is using the 12M for midrange only, with the Jehnert-supplied soft-dome tweeter. I would LOVE to see photos of this installation, and also hear what it sounds like. I don't have any info besides what's in the thread above, if you contact him and find out more, please share!
