Speed Dependent Volume - Head Unit or Tuner?
kwontumspeed
Where is this controlled?
I'm starting to get a slight popping/static sound when it moves passed the mph intervals. Don't really have a way to isolate without having an extra unit. Ideas?
I believe the head unit uses the same Hall speed signal which comes from the back of the speedo (yellow/green wire). Might be able to disable the function by disconnecting the appropriate wire from the radio? Otherwise, it's the radio causing the noise, if you want to fix it.
:gsxrock:
Nice, thanks Dave. Seems easy enough.
Definitely want to fix it. The popping follows the decibels of the radio, so when I'm jamming to Tom Jones at 11...:deniro::LOL:
Yeah. @kwontumspeed I assume by the phrasing of your question (tuner vs. head unit) you have a 500E, and, therefore, a Becker 2 pc system with the tuner module in the trunk?
See wiring diagram below. @gsxr is right ---- it is the GN/YL wire and that wire only goes to the Head Unit ---- and not to the tuner module in the trunk.
Thanks @Jlaa.
Wonder if the system is giving me a sign of an impending failure, and hopefully not the speedo. It's a combined pop/crackle for the half second that it passes the speed mark on its way up and down in velocity. Anyone else experience this with the 036 system?
