WANTED Steering Pump
@szvook, what was the issue with your old / existing pump? Make sure to re-seal Steve's pump before installing - in particular, the front shaft seal should be fresh. If the S-hose isn't recent, it's cheap to replace while the system is empty...
Yes, unless something is wrong mechanically with these pumps, they can easily be re-sealed. There is a HOW-TO on this in the forum for anyone who needs the reference.
@gsxr @gerryvz My original pump is leaking quite a bit. The shop my mechanic uses to reseal the pump is closed for renovation for about two weeks. I need to drive to San Francisco for work this Friday, so I need a pump with no leaks in the meantime.
It took 187K miles in order for my original pump to leak and I will have it resealed. With the pump with only 53K miles, the seals should be ok. Time will tell.
Good , hope it helps you out. AsI said the motor only had 53000 miles & has been carefully stored inside & covered up all the time I have owned it
If you have time for a short drive down to San Carlos while you're here, we should connect.
It is my unfortunate circumstance to also be in search of a new (rebuilt) pump for my 94 E500. False leads everywhere.
Is the 94 pump unique from it's earlier non-94 predecessors?
Always grateful, Charlie
Charlie, the pumps are the same across all years of E500E. There are both ZF and LuK/Vickers pumps, also interchangeable, but the seal kits are different.
What is wrong with your pump? The typical failure is the front shaft seal, which will cause a significant leak of SLS fluid (not power steering fluid). Usually re-sealing the pump is all that's needed.
Front seal per my indy. Forum how-to’s inform me that it’s a pita to get out and back and I’m no longer capable. So, wanted to bring car and rebuilt/new tandem to him to swap. I’d then bench re-seal /rebuild and (hopefully) re-sell. I can’t be the last guy looking for one. Or maybe I am😳
My baby is becoming a BOAT as in Break Out Another Thousand.
Dave, yeah, I was certain it’s not PS by the smell (actually the lack thereof) but while he was doing the upper harness and ETA I asked him to run down the hydro leak.
Thank you as always for the advice.
Another option is to try and locate a pump from an R129 or 140 chassis, they are nearly identical. If you found a good core, you could send it to C&M Hydraulics for a rebuild. Or, contact C&M and see if they happen to have a pump in stock (with core/exchange).
:jono:
C&M website indicated nada. My indy found one at $599. Ouch but I can’t execute a “have him pull it at his garage” and re-seal in mine. Since I’m going to take it in the shorts for the R&R I figured I’d cry once and then enjoy my ride once the snow clears. BTW, what is the proper MB lube for this?🥺
I hope the $599 unit is actually available. Not sure I've seen any in stock in a loooong time.
C&M may not list anything on their website, you need to call and ask.
I like Genuine MB power steering fluid but any Dexron ATF will also work. Should need less than 1 quart total.
Any ZH-M hydraulic fluid should be ok for the SLS side.
:3gears:
I just realized that I had not followed up with C&M, I had been talking with one of the MB guys at one of the online sites. The C&M was listed there as not available and I conflated his response with my neglected intent to call C&M. Indy called me with his message and so I fell to my knees in relief and abandoned any alternative search. I doubt it’s new.
I do appreciated your advice.
Regarding fluids, I inadvertently left 2 units in my cart when I found and ordered the NLA then not-NLA lower radiator house and already had a couple while I fought through the fluid loss discovery previously. This I fixed with the posted how-to specific to 94s. Lot of work for 2” hose. Ergo, lots of MB PS fluid. I also have plenty of the MB hydro fluid. I can probably suck a bunch out of the cardboard under the car😢 The cost diff is mice nuts compared to the ETA, upper harness and now this expense in the last 2 weeks.
Re: availability, they told him Wednesday, I didn’t ask who from (I didn’t want to put the malocchio on things - I’m not superstitious but I am a little stitious.)
I hope it’s the right one. I found the online sites served up a pump based on part number but then precluded hydro shocks.
