Weird. Next up is removing the console wood checking both cables next to the shifter.Dave, the shift lever will NOT move with the key turned and brake pedal depressed.
Definitely sounds to me like the neutral safety switch, given the new information.Please make sure you check your shifter bushings and also the functionality of the neutral safety switch, if you haven't already.
It's a good possibility, yes. You can also try applying +12v to the center male pin and see if the starter engages. If not, the solenoid is probably bad.Question, I get +12V at the center pin of the 3-pin harness behind the CAN box when the key is turned to the crank position. Would this indicate the starter?
+1, Glen, I think you made the right decision. Now, get all of your extensions and knuckles ready.Eh, nevermind. I ordered a rebuilt one from AutohausAZ.
I had a starter issue on my Limited, likely due to long time storage, but a starter refurbishment fixed it (post #27):Thanks Terry. I put that starter in 6 or 7 years ago so I’m pretty familiar with the procedure, too bad it didn’t last longer though.
Glen, how many miles on the failed starter? Assuming it was purchased new/rebuilt, any chance it may still be under warranty? If it was still spinning fast, sounds like the only failure was the solenoid.Thanks Terry. I put that starter in 6 or 7 years ago so I’m pretty familiar with the procedure, too bad it didn’t last longer though.
I had to check my records, it was just over 7 years ago and almost 70K miles. It was a rebuilt Bosch unit from AutohausAZ...same one I just ordered. Their warranty is 3 years/36K miles. Maybe I should have bought it from FCPEuro? Oh well, I will probably sell the high miler before this new one dies.Glen, how many miles on the failed starter? Assuming it was purchased new/rebuilt, any chance it may still be under warranty? If it was still spinning fast, sounds like the only failure was the solenoid.
Good call on buying a new replacement, btw. Check into the warranty terms on this one.
Glen! You can't sell it until you hit 1M miles!I had to check my records, it was just over 7 years ago and almost 70K miles. It was a rebuilt Bosch unit from AutohausAZ...same one I just ordered. Their warranty is 3 years/36K miles. Maybe I should have bought it from FCPEuro? Oh well, I will probably sell the high miler before this new one dies.
He will be driving electric cars exclusively before the hi-miler hits 1M miles !Glen! You can't sell it until you hit 1M miles!
Never exclusively! More electric cars are definitely in my future but I will never sell my 744 E500.He will be driving electric cars exclusively before the hi-miler hits 1M miles !
Yes, FCP Euro FTW, for just that reason.I had to check my records, it was just over 7 years ago and almost 70K miles. It was a rebuilt Bosch unit from AutohausAZ...same one I just ordered. Their warranty is 3 years/36K miles. Maybe I should have bought it from FCPEuro? Oh well, I will probably sell the high miler before this new one dies.
Not that I am planning to do this, but is cutting the cables the only way? It doesn't appear that those wire ball sockets can be disconnected easily, but can't the sheath just be hooked off?Weird. Next up is removing the console wood checking both cables next to the shifter.
To release the shift lever, both cables should be extended, so the small spring is pushing the ball/socket away from the cable sheath.
Side note: To permanently disable either or both, cut the cable(s). The springs will keep the interlocks disabled / unlocked and return to early-124 functionality.
The mechanism must be locked into the extended position, and the spring on the end of the cable does this.Not that I am planning to do this, but is cutting the cables the only way? It doesn't appear that those wire ball sockets can be disconnected easily, but can't the sheath just be hooked off?
I replaced mine around 93K miles soon after I bought the car w/ 89K on the clock. I bought a reman from Mercedes of Anaheim. I have the receipt somewhere. If I remember it was around $100.00 +/- at the time. Still working at 143K miles.In my experience with my cars the starter motors and alternators should have a service life of 100k miles / 20 years without issue. This assumes semi regular use.
For example a long lay up outside could damage a starter motor solenoid so this would not be considered a "typical" failure.
What I have done on my cars is any time I am performing maintenence which requires either the starter or alternator removed I get them refurbished proactively.
I have mentioned before - I have a local specialist rebuilder very close to home. Does a top job and warranties his work. I trust his rebuilds and NEVER had a single failure 10+ years and counting after he rebuilt them.
These are the original Bosch / MB parts expertly rebuilt and tested.
I think the mistake many people make is getting a parts store refurb / aftermarket unit. In which case sadly they will only last a couple years and be ready to swap them out again- keep your receipt. Original high quality parts for the win! Repair what you have it's much better or source a Bosch rebuild etc. Nothing else.
Hello Guest !
