sunroof rear "moves" when I shut the door
samiam44
I just noticed this- It is pretty big, maybe the rear edge needs to be adjusted up a bit? Maybe a slider
Michael
I've always seen the sunroof "move" a bit when I shut the doors on my cars. It's due to the air movement and relatively sealed environment inside the car. I've never considered it anything to worry about, honestly.
If you've never done a full sunroof service (remove, clean, lube, re-install) do that first... usually a once-per-ownership job.
Otherwise, as Gerry said, I wouldn't lose sleep over it as long as the sunroof is working normally.
:pc1:
