The $500 S500 limousine project got interrupted when I stumbled across another cheap M119-powered car I couldn't pass on. I found this one on a small town Craigslist auto parts section. It's a 93 500SL.
The seller was asking $1099 and noted that the car had a fuel leak, rough paint, and had not moved in years. I texted and got more details. The car had been parked around 2012 when it developed a significant fuel leak and the prior owner never got around to fixing it. In 2018 the car was donated to a church in Twin Falls, Idaho. The church had planned to eventually repair it in hopes of getting more money out of it, but after sitting on it for several years, they decided the cost to repair it would likely be more than the value of the car, so they finally decided to sell it.
Twin Falls is about 2 hours from my home, and I knew that if I made the drive to pick it up, I'd bring it home, so I was only willing to do it if I knew that no matter what I found, the car would be worth it. I offered $500, and surprisingly they agreed so long as I could come right away and pay cash.
Two and a half hours later I arrived and made the deal. I also discovered that the car had a nice set of Evo wheels. I towed the car back and got to work.
The car was in an accident at some point and was poorly repaired and very badly repainted, and the respray is failing. The tires are 20 years old, cracked and flat spotted. The interior is a bit tired. Mice had taken up residence at some point, and had made nests in a few places. Mouse droppings were everywhere.
That first evening I swapped in a good battery and tried to start it, but found there was no fuel pressure. I added fuel to the tank, but still no fuel pressure. I ordered a pair of cheap Chinese fuel pumps and a filter next day from Amazon.
The next day I swapped the pumps and the car fired up and ran surprisingly well. The convertible top has major hydraulic issues. The motor mounts are tired. The wiring harnesses are all original and are beginning to deteriorate.
The car is definitely not worth restoring, but it'll be a great parts car, and something I can play around with for a while before I do part it out. I had been working on welding two W140s together into the worst limo ever to run the Gambler 500. Details on that build here:
www.500eboard.co
With the SL now running, I had to decide what to do with it. At this point I was getting burned out on the limo project, which was just a farce anyway, so I decided to just part out and scrap the limo, and build up the SL into a Gambler 500 car instead.
With the limo gone, I got the SL on the lift and started hacking.
The plan here is to modify the SL with some much larger tires and then hack the body for clearance. The tires are some used 265/70R16 all terrain tires mounted on the W140 wheels from the limo project. To push the tires out away from the suspension and chassis, I acquired a set of 1.25 inch wheel spacers. I had to swap out all the hardware to make it work.
These spacers have two inner bolt patterns, 5x110 and 5x112, and one outer set of studs at 5x112. I got a set of taper seat 24mm m12x1.5 wheel bolts, and a set of M14x1.5 wheel studs for a Ford F350 Super Duty truck, and a set of Porsche ball seat lug nuts.
This set up actually worked great to get the wheels bolted up. From there I had to do a ton of cutting, hammering, welding, and more cutting for clearance.
I've taken the cutting about as far as I can. The car can be driven as it is, but there's significant rubbing on bumps. I think my next step will be a small suspension lift.
The $500 S500 Limousine | Off-Topic Discussions
If you've read the $400 400E thread you may already be familiar with this project. If not, welcome to my side quest. The short version is that I'm putting together the most absurd vehicle possible with plans to run several Gambler 500 events throughout Idaho and the northwest this year. For...
