Where can I get the color combo information for you guys? The paint is white and it has the blueish interior and gray lower exterior panels. Location is in Willow Spring, NC 27592.
Price? I"m not sure at this point as I'm not sure of it's worth. It's not drivable right now. Engine ran when I parked it. I had the trans replaced with a used one. Original rear end. It has new shocks in the rear (bilstein). I have the strut mounts I was going to use to replace the ones in the car which are bad.
Options: I"m not sure what options it came with. The original radio was replaced with an aftermarket radio. It has a/c, power steering, power windows, power door locks, power seats, automatic trans, power antenna that doesn't work any longer. I have a replacement antenna I was going to put in it.
The shop I used to replace the trans started the car to test the trans and a small electrical fire occurred under the hood on the drivers side. I never got it fixed. The upper harness was replaced and I had the lower harness rebuilt (guy in GA did it for me). I'll add more as I it comes to mind.
Found the title and the VIN is WDBEA34E0NB681748.
Any other info you guys need?
