Hello All,
Sorting through the bugs on my newly acquired E420, was inspecting the Kickdown Switch and found that 2 out of 4 terminals on the connector to the switch were empty? Only two wires are actually pinned and go to the switch at points 2 & 4... meaning on 1 & 3 there is nothing. Is this the way it is supposed to be? Pictures attached:
The kickdown switch has seen better days and seems my kickdown's are only working via bowden cable from 4-3, 3-2. I will also 12v check the kickdown solenoid once I get a chance...
In other news, my NSS is going out and car only starts in N now, not in P. Replaced shifter bushings that were shot, but no luck and NSS part is NLA. I would like to bypass it altogether with an inline fuse via the purple and purple/white wires in the cabin under kick panel but not as easy to access those as earlier models it seems from poking around. I know none of you will recommend me bypassing the NSS permanently but it is the most logical solution and I am smart enough to only start the car in P or N lol... Any tips appreciated regardless.
Thx,
ANDERZÉN
Thx,
ANDERZÉN
