WANTED WTB - EZL for 94 E500
tanger
Looking for I believe either A 015 545 61 32 or A 015 545 62 32 (interchangeable?).
Anyone have leads on a working one?
I have this EZL part # 0135456432
This came off a low mileage 1993 500E crashed car 14 years ago & has been in dry storage since.
$200+ shipping
013-545-64-32 should work fine on the 1994 E500 in place of the original 015-545-61-32. You don't want the -62-32 which made by Bosch instead of Siemens. The Bosch units are not known for having a long lifespan, Siemens can last the life of the car. But yes, 61 and 62 are functionally equivalent.
If you want a 015-545-61-32 part number specifically, drop me a line. It's not necessary though, unless you want date codes to match or something.
EDIT: The only combination I have never been able to test, is if an earlier (non-015 prefix) EZL will work on a late M119 engine with open deck block. The latest EZL's are backwards compatible with closed-deck, but I've never owned an open-deck block to test with. At least with closed deck blocks, all 5.0L EZL's are interchangeable.
Thanks for your input, as always, Dave
