WANTED WTB Need fan shroud for a 1992 500E
rockingchairmotors
Active member
Hello
I need a fan shroud for a 1992 500 E. Mine broke when removing it. I need both pieces. I have been told from forum members that the shroud from any year 400E or E420 will work also. I Need it complete including working flaps and connections.
Thanks in Advance. To be shipped to Nazareth PA 18064 or I will pick up within a couple hundred mile radius.
Jeff
Hello
Jeff
i am pretty sure any M119 w124 and maybe W140 or R129 fan shroud would work try local pick n pull sir
The odds of getting one that isn't broken at the connection point is slim. Zip tie is your friend, or buy new but use anti-seize to begin with[emoji857]
Jeff, they should still be available new if you are unable to locate used.
124-500-12-55 = upper, $80 MSRP
124-500-13-55 = lower, $124 MSRP
Naperville should have the pair for ~$150 total delivered to your door.
I believe I have the upper and lower sections from the last E420 but the hardware connecting them is missing, but otherwise complete. I don't recall if they fit into a large flat rate box.
$55.00 + shipping.
I'll try and post actual images later today
Jeff
Jeff, these will definitely not fit in a flat rate box. But, they are light!
:rugby:
I found it and it does have the hardware. I must have been confused with another shroud.
Jeff
