Ahhh…the smell of chlorinated brake cleaner in the morning!
I’ve had the parts stocked for quite some time, but today was the day I finally began addressing my current deferred/proactive (which unfortunately aren’t self-cancelling) back-burner maintenance list items.
I’m focusing on the sources of any niggling fluid leaks. My primary focus is the power steering pump reservoir short hose which certainly appears to be the main culprit. The hose has been changed under previous ownership, but now it is my turn.
During the dismantling procedure I discovered three E10 torx bolts &
one 5mm allen bolt holding the reservoir on its bracket (kinda made me wonder what the fate of the original 4[SUP]th[/SUP] torx bolt was). A replacement torx bolt will be added to my parts order list to correct this situation.
I’m pleased to verify that the LUK power steering pump & the steering box pitman arm shaft seal are not leaking. I still need to verify the cam solenoid.
I also believe the valve cover gaskets are leak sources. New MB gasket kits are on order. I will then install my metal cam oiler tubes, starting with the driver side. The plastic oiler closest to the fire wall voices the “tick-tick-tick” of a blown cap. Spark plugs will get changed & upper timing chain guides will also be inspected & most likely replaced.
The poly v-belt still looks quite good but will be replaced because of its age. The old will be kept as a backup spare. My
ML55 150A Bosch alternator will be installed. A new voltage regulator is on order. The old VR is still decent & will be kept as a backup spare.
My upper harness has been PO replaced, but while inspecting the alternator connections, it appears that the lower harness has not. The smaller diameter wires’ insulation is looking unhealthy. A replacement harness will be ordered & the source of oil leak on this side of the block will be remedied.
The driver side distributor cap & rotor look OK with normal wear, but will most likely be replaced because they are over 5 years old. One of the cap mounting bolts will be replaced because its socket is a bit sloppy & I remember other members' horror stories of rounded off sockets...not gonna happen here! Naturally, this particular bolt resided in the most difficult to access location. I was able to remove it without much difficulty using my long reach 5mm Allen socket on 3/8" ratchet.
Looking forward to finally taking care of these jobs & making the driving experience even more pleasurable than it already is!
