You've been riding on that stock setup a good long time. Any noticeable difference in the ride and handling?
Lug bolts seem a bit long, Derf, no? :?
I've got all winter to find them.
... I am doing the lower harness first, ...
... I still need to verify the cam solenoid.
...One of the cap mounting bolts will be replaced because its socket is a bit sloppy & I remember other members' horror stories of rounded off sockets...not gonna happen here!
The picture looks like (could be just the flash) the pressure hose may be weeping sls fluid.I've added additional info to the Lower Harness HOW-TO you may not have seen yet.
My lower harness condition was a recent discovery made while underneath visualizing my alternator replacement plan of attack. I'm glad it hasn't caused any problems up to this point.
It's replacement falls right in line with the upgraded alternator & new v-belt installation.
The PS short hose has been bugging me pretty much since day one. That one oil tube has been a close 2nd. Looking forward to crossing them all off the list & liberating their storage space.![]()
Oil level sensor is a common leaker. Also, if you don't pack rags or paper towels between the oil filter housing & frame rail when replacing the filter, oil dribbles down the outside of the filter housing, making a nice mess below (which you may never see, if you use a TopSider!). Valve cover gaskets are NOT a common leak if they are OE, installed & tightened properly. On almost all of my cars, oil leaks from high above have ended up from the cam solenoid area... which can be one of 3 different things on the solenoid (sealing surface, body halves, or electrical connector). The airflow from the engine fan moves oil around, so don't rule out sources like the front crank seal, timing cover to block junction, and main/upper oil pan gasket.The flash does make things look so much worse than reality. SLS hose is fine. It all appears to be engine oil weeping down from above (I'm betting primarily on the oil level sensor oring & perhaps the valve cover gasket to a certain extent).
...I need to get a replacement torx bolt for mounting the reservoir to its base. I'll finalize a parts list for current needs & send it out.
Tomorrow I should be receiving the new rotors & voltage regulator. The left distributor cap & rotor job will be completed & the 150A alternator will be ready for installation.
...I've opted to wait until tomorrow when I will use a hot air gun to warm up the breather hose for safer & easier removal from the cover. The hoses aren't old, but I'm not taking any chances applying force to them when cold. The cover will then be removed & I'll start replacing the oiler tubes.
...I started removing components for the driver side Cam Oiler Tube Replacement job. I discovered two loose valve cover bolts which may have been minor engine oil leak contributors (I'll have a better view of any evidence once the cover comes off).
Thank you, Kind Sir. Please take some detailed photos of the popped-cap oiler tube. It would be good to get some documentation for the forum of what that looks like.
How did the timing chain guides look?
Good work, doctor !!Shall do. It will be the first one I remove tomorrow. I took a detour after lunch to the rotor & alternator install.
Previous stethoscope testing told me that the bad tube was one of the last two on the right end. I used an o-ring pick to probe those tube ends to verify the popped-cap perpetrator.
The top/center ones with the "fingers" may break apart when you remove them. Try to avoid dropping plastic bits into the chain cavity.I haven't scrutinized yet, but the upper looks alright at first sight. I'll know for sure upon removal.
the 150 amp alternator upgrade was the single most noticeable improvement I did on my car, I would recommend to anyone
...The rails you really want to inspect are the ones on the inside of the "V" in the head, you can only see the top tips of them. Make sure the tops are still intact. Look down below with a flashlight to see if the lower tips have snapped off, the lower tips may be sitting in a cavity inside the timing cover until replacement time.
I took the opportunity to remove the entire remaining old petrified protective wiring loom from the engine compartment. Most crumbled away with a squeeze between my fingers.
I replaced the majority of it with new Del City grey-stripe high temperature 0.25” ID split loom (Temperature range: -40° to 300° F / -40° to 149° C). The loom fits perfectly within the rear oil pan trough & the various block-mounted snap-in clamps.
Good again for the next 20+ years.
