Another question
...You guys are so helpful I got to take advantage of it
. What controls the "Auto" function on the AC console? Is it the cabin temp sensor above where the sunroof buttons are? Whenever I set "Auto" its is always little slower than "High" option...But it never goes down...
There are a number of inputs to the 'AUTO' mode for the automatic climate control system. One of them is the interior temp as read by the cabin temp sensor, as you mention. However, there is logic inside of the ACC pushbutton control unit that controls things. Other inputs obviously include the temperature setting on the temp wheel, the ambient temperature (if not set on "recirculate" mode), and the mode setting button pushed. Another input is the evaporator temp sensor, I believe.
The HIGH fan setting will always push maximum air volume, and the LOW fan setting will push minimum air volume. The AUTO setting has some variance (mainly depending on the temperature setting thumb-wheel -- AUTO fan speed will slow down when warmer temps are selected in the upper part of the white and red temp zones), and it is always between the two, but from my experience over many years is perhaps about 10-20% less air volume than HIGH is.
For Southern climes with high heat and humidity, it's best to always have the MODE push-button in the "Normal" (middle button) setting, and have the fan on AUTO (or HIGH if super hot out).
If you rotate the temp thumbwheel to the coldest setting (the "dot"), you will feel a small "click" at the lowest part of the temp setting. This click puts the entire ACC system in "recirculate" mode -- same as hitting the recirculate button. Note that the recirculate button turns off to normal circulation mode after a set time; it is designed for rapid cool-down of the car's interior before reverting to allowing cooling of outside/ambient air.
If you slightly move the thumbwheel upward (off the click) then it will be max A/C with non-recirculate mode, unless as above you've hit the "recirculate" mode for temporary recirc of cabin air.
My biggest complaint has always been that the HIGH and LOW fan speeds are too fixed, and are not optimal. AUTO is always too high. The ACC system has always lacked in terms of having the proper logic to set just the RIGHT fan speed itself, and of course you can't set it manually. It's sort of a Henry Ford "you can have any color you want as long as it's black") deal -- "You can have any fan speed you want as long as it's too high or too low"). The four-speed manually adjusted fan-speed in my 1995 G-wagen is a real God-send......
I hope all of this makes sense. GSXR will very likely tell me I'm all wrong, so please take the above with a large grain of salt.....I did my best though. :?
