Correct. It's a decent Group III oil, but it should be changed at 3-5kmi intervals. Don't use it for extended drains.It's fine .... Just change it at or before 5K intervals!
Oil I can recommend:
Fuchs TITAN SYN MC SAE 10W-40 it is semi synthetic. German one and very good quality, it has lot of recommendations - also the VW 505 that normally goes for full synthetic products.
For this year I have bought Valvoline Racng VR1 10w60 - to be tested.
s
That oil will be My-Tee-Fine for your Southern weather.I am leaning toward Redline 15w50 for NC weather.
10W60!! Holy Crap. I've been reading a lot of the Bob Is The Oil Guy posts, and most over there seem to think it would be crazy NOT to put 0W-20 synthetic in every car. Extensive oil analysis shows no undue wear occurs. All the new cars use this and most old cars have been back spec-ed to this. Ford back spec-ed its crown vic V8s back to 1992 to use 0W-20! This is progress man; this is technology, film strength, film thickness. I have not tried it yet but I will with the next oil change an I expect the following: better lubrication on startup, when most wear occurs; shorter time for oil and coolant to come up to temperature, because a thinner oil gathers and releases heat faster and because the the oil pump will be able to pump more oil for a given time; better gas mileage; and here is the best part, quicker revving. Seriously, I've messed with pedal, cable, linkages, etc. trying to get a decent pedal feel and good revving- lubed, polished, replaced, remove the spring in the pedal And it has helped a little. Bit lighter oil should help some too. I also expect oil pressure to be lower at idle (650), but this shouldn't matter because I expect oil pressure to rocket well past max well before 1500 rpm.
I ordered some Mutol oil and filter from FCP on the 21st.
Which Motul oil?
I use this 5W40
Clark,
I hope that it is a good oil, but it is certainly better than the Mobil 1.
Which Motul oil?
I use this 5W40
Has anyone been using Castrol Magnatec 5w-40, or Castrol oils in general, in a m119? It does appear meet MB 229.31.
I've used it for almost all of my previous cars and it's been a great oil. I'm not sure whether it's for sale in the US, but do the euro members have an opinion?
5W40
For those of you running Motul now (and future users), I'm curious to hear how your engine sounds and feels now?
That's my feeling as well. I'm curious to see how my UOA's turn out.... Amazon Prime makes it a 2day delivery with free shipping for $11 so I am happy with the price. Maybe Motul is slightly better, but I don't think it's worth the premium.
If you are referring to the 300V oils, then yes, no API ratings are given...aside from this one "OEM Approvals: Above existing Motorsport standards", which works fine for me.Motul oddly doesn't seem to have API ratings.
The CURRENT Mercedes approvals still do not allow xW-20 viscosity. The 1994 approvals were even more restrictive, no 0W-xx oils were approved at all
You still have not provided any solid evidence that thinner oils will provide better wear protection, faster warm up, or a more responsive engine. All of the above are highly subjective. I noticed that engine longevity wasn't mentioned.
If 0W-20 was all you and BITOG have cracked it up to be, Mercedes would be issuing TSB's to their dealers recommending its use for oil changes in all years/models. Oddly, this hasn't happened yet. Tell you what, you use 0W-20 in your M119 for the next 5 years in all different climates, including -10°F to +110°F ambients that we get here in Boise, and let us know how it works out. Include UOA's from various mileages, and monitor consumption as well. We'll be patiently waiting.
LOL. Very true. Debates over recommendations that conflict with Mercedes specs should take place on BITOG, not here.Oil threads are almost never constructive. Like discussing politics or religion, it's generally not a good idea.
and the Motul oddly doesn't seem to have API ratings.
Fair warning: If things get out of hand, this thread will be closed.
Other then the 0W20 issue, I think this oil thread has been productive.
I believe all the oils discussed, Red Line and Motul are both good.
Also the diesel oils Rotella and Delo have their place.
Sorry, I meant the 300V specifically.Yes, actually they do. At least the Motul "street oil" I use.
In fact, a very good API rating.
Aye, you are correct.Also the diesel oils Rotella and Delo have their place.
Are you making that recommendation to clarkz71, or to Maui?Remember to change the filter first, BEFORE you drain the oil (or at least, before you put the drain plug back in). When you remove the filter, it lets the filter housing drain into the sump. If you do it backwards, you end up leaving a half-quart of dirty oil in there.
That's a useful piece of information. Generally I remove the drain plug and then the filter while the oil is draining.
