OK guys I have the shocks in my hands.
For unmodified the end fittings the price is USD 55/shock shipped in the USA only.
For international shipping the price will be determined depending on the cost of shipping. I will provide you with a tracking number once the items are
shipped.
I will include a PDF or paper instruction for how to modify the end fittings and the plastic slot where the end fittings are going in. The modifications do not change the stock look of any of your car's parts. It is not a very hard procedure, but still be careful.
Here is some hints although I am sure most or all of you know what they are doing more than I:
1. Buy and install new protective strips that were posted earlier on this thread before installing the shock. They are only a couple of bucks from the dealership. If you do not you may overextend the glove box hinges and damage it.
2. It will be easy to remove the old bad shock, but it is a bit more tricky to install the new one because it is harder to compress by finger pressure. Make sure the plastic that holds the hinges is in a good shape and not cracked from old age. Overall placement is not very hard.
3. The shock has the exact pressure specs and total length of the OEM stabilus one. The only difference is the thickness of the end fittings.
I have checked them all, and they seem all functional, but if you get a defective one send it back so that I can confirm the defect and I will replace it. I will not replace items with damaged end fittings due to modification and I do not have extra end fittings so just be careful. I will only replace items if the shock itself breaks within 60 days. These are rated for 10000 cycles at least so they should be good for years unless they fail after the first few.
Just pm me if you are interested in the unmodified version with your name address, and email and paypal me depending on how many you want at
ivanned@u.washington.edu.
If you want modified version you have to let me know. I will have to increase the price and it will take some time mostly due to the hurricane power outages.
Ivan
