1994 E500 125K miles
Blower motor intermittent at first, then failed. Motor had been replaced with Behr/Hella unit 1.5 years ago so suspected regulator/controller. Verified 12 v at regulator connector red lead, 1.3 v at regulator control lead with fan push button on low, 7.6 v at control lead with fan push button on high. Believe this is normal and verifies function of dash control unit. Connected 12v battery charger directly to fan—fan spins but draws 10 amps (maybe more but charger amp scale tops out at 10). Fan seems difficult to turn by hand, can get maybe 1.5 to 2 turns with max manual spin effort. Anybody know what normal current draw might be? or if that much “spin drag” is normal? Beginning to think motor bearings are just to stiff for the amount of current supplied by regulator. Ferris, Anyone?????
