Dry Ice treatment is obviously a very specialist process. It is gentle enough to exfoliate dirt & light corrosion but not harsh enough to damage the rubberised factory undercoating. This is also down to the operator to know when to move on and be gentle.Nice! But a couple of concerns:
1 - Isn't this removing undercoating/wax ?
2 - It the dry ice abrasive to plastic/rubber/paint ?
I've seen it used to sandblast cars for paiting (without sand), also saw a case where is used for the engine compartment to remove oils and grime.
Nothing came up in the searchable Cal smog testing database.Anyone recognize that 500E? Wonder if the VIN could be determined via the license plate...
Here's a no-name machine that costs a fractionI totally need one of those. Wonder what they charge (per car) for folks lucky enough to live near Costa Mesa, CA.
And does the Coldjet PCS60 really cost $90k as claimed...?!! Of course, I can't find official pricing anywhere.
Aero2 PCS 60 - Precision & Versatile Dry Ice Blasting Machine | Cold Jet
The Aero2 PCS 60 is a precision dry ice blasting machine designed to give the user complete control enabled with Cold Jet's Industry 4.0 solution. Call now!www.coldjet.com
But it would appear that you'll need a pretty massive air compressor as well, so factor that into the cost.Here's a no-name machine that costs a fraction
Toolots, Inc. - Reliable Equipment Fast.
www.toolots.com
$2700 probably gets you a HF-quality machine with zero post-sale support. But a couple of jobs and it's paid off.
WDBEA36E8PB852360Anyone recognize that 500E? Wonder if the VIN could be determined via the license plate...
WDBEA36E8PB852360
I couldn't figure out what compressor size was needed. Hmmm.But it would appear that you'll need a pretty massive air compressor as well, so factor that into the cost.
Maybe the ice blast is in preparation for a BaH listing?WDBEA36E8PB852360
Most likely headed for Bat againFOR SALE - 1993 500E Pearl Black/Black, 94kmi, $65k (Austin, TX) | Cars for Sale - 500E / E500 ONLY
Admin Update 1: As of 7/2/2018, car is listed on BaT at this URL. Admin Update 2: Listed on eBay July 2018, price reduced to $38k. See post #20 for details. Admin Update 3: Back on eBay February 2019, price reduced to $37k. See post #24 for details. Admin Update 4: Price reduced to $32k...www.500eboard.co
That's crazy high air consumption. Looks like a 15hp+ industrial compressor is needed, likely either 3-phase or even gas powered, just to hit the minimum 50cfm. I found some that met the minimum requirements, ~$5k, 3-phase... prices go up from there:See bullet #5
Depending on rental rate, maybe another reason for a working GTG . . .
- Air consumption 50-215 CFM at 80 psi
A portable gas compressor rental would not be that bad. Probably about $100.00 per day or less plus drop off and pickup fees. I think that would get you a pretty high pressure rig. There are 100s of construction equipment rental companies out there with a lot of equipment just setting.That's crazy high air consumption. Looks like a 15hp+ industrial compressor is needed, likely either 3-phase or even gas powered, just to hit the minimum 50cfm. I found some that met the minimum requirements, ~$5k, 3-phase... prices go up from there:
Air Compressors | Fergusonhome.com
Shop Air Compressors on Ferguson Homewww.aircompressorsdirect.com
If there were a place here in Northern California, I would avail myself of this service in a heartbeat......I would love to do this to my car. How much for the service? I would have to see if anything like this is available near me (Bay Area California)
Guilty as charged. Risk / Reward on this activity for DIY w/ /jack stands, gasoline, respirator, etc. is unattractive.You guys are all a bunch of wusses.
Jack your car up and get under there with brushes, rags and mineral spirits like I did.
Results are the same and you have the satisfaction of DIY!
One caution - once you get it clean, you have to keep it clean.....
i have found that not much seems to make a difference against years of baked on cosmoline other than the strongest of solvents?Oh no, never gasoline.
Low odor mineral spirits and this Dawn Degreaser is amazing.
I'd daily drive the hell out those tooBut for collector/show cars
I think some Proposition in CA should have already banned this? I mean, if not, I’m utterly shocked (since they turned over the methane emitted from cows use case already) and we should turn the authorities on to this as it will contribute to the greenhouse effect.This is definitely not for a typical daily-driver car, or any car driven in inclement weather. But for collector/show cars, and/or folks who live in dry temperate climates (coughCAcough), it's a less intrusive method to clean underneath without damaging either paint or other items sensitive to solvents/degreasers. Not to mention far less labor intensive vs the toothbrush and Spray Dawn Nine.
That would be to simple and not fun. They'll come with a proposition that mandates dry ice cleaning to be powered by 100% renewable electricity or risk facing a steep fine. Thus making this service even more expensive, and out of reach for middle class. I think that'd be inline with the California wayI think some Proposition in CA should have already banned this? I mean, if not, I’m utterly shocked (since they turned over the methane emitted from cows use case already) and we should turn the authorities on to this as it will contribute to the greenhouse effect.
Robert
Agree. Not many products that don't have a hazard triangle on the bottle will touch the stuff.i have found that not much seems to make a difference against years of baked on cosmoline other than the strongest of solvents?
If Jonnie Cochran would have had you present the whole trial would have been over much sooner.My gravel road laughs at your efforts to clean (and keep clean) that which cannot be seen.
Shut up! We have enough restrictions.I think some Proposition in CA should have already banned this? I mean, if not, I’m utterly shocked (since they turned over the methane emitted from cows use case already) and we should turn the authorities on to this as it will contribute to the greenhouse effect.
Robert
Exactly my point. You'll drop nearly as much for a compressor, *if* you have the juice to run it.That's crazy high air consumption. Looks like a 15hp+ industrial compressor is needed, likely either 3-phase or even gas powered, just to hit the minimum 50cfm. I found some that met the minimum requirements, ~$5k, 3-phase... prices go up from there:
Good thing there is 3-phase within sight of my shop. Hmmm, wonder if they will let me have 480v or only 208v... LOL...Exactly my point. You'll drop nearly as much for a compressor, *if* you have the juice to run it.
The distribution feeder is probably 11.7kV, so it really doesn't matter. However, if you're considered to be in a residential area, the surcharge that most utilities apply for three phase service is pretty steep. Someone has to pay for those transformers...Good thing there is 3-phase within sight of my shop. Hmmm, wonder if they will let me have 480v or only 208v... LOL...
I know... that would be the down side. My neighbor 1 lot away has a shop with 3-phase, and there's a power pole with 3 transformers on it, 150' away from my shop corner. Still would be spendy to bring that over the lot in between and add the new panel.The distribution feeder is probably 11.7kV, so it really doesn't matter. However, if you're considered to be in a residential area, the surcharge that most utilities apply for three phase service is pretty steep. Someone has to pay for those transformers...
I had a single 400A service in my "Momolith" (4,000 sf house) in Indiana. Just for grins I checked with our utility and found I could get an additional 400A service or a single 800A service if I wanted it. I had all kinds of woodworking equipment in my basement shop and when turning on a big 240V machine, like my 16" planer, the lights wouldn't even flicker. Loved it.You have two 400A services? On the same building, or one residence / one shop?
Hello Guest !
