1994 E500, 124K miles
Engine running on 4 of 8 cylinders. Permanent condition, not intermittent. Pulled drivers side coil wire, no change. Reconnected drivers side coil wire and pulled passenger side coil wire, engine would not start. Concluded no spark delivered to drivers side rotor. Removed drivers side cap rotor and insulator, no visible damage, carbon traces, or moisture. Tried new ignition coil on drivers side, no fix. I have two known good EZLs, tried but no fix. (Yea, I know, hope I didn’t fry three EZLs due to bad coil, wire, etc..... Just seems very unlikely). Now thinking it could be the coil to rotor wire—would like to replace it and see what happens. All ignition components have been replaced during my ownership so would prefer to start with just the coil to rotor wire. Anybody know of a source for just this wire? All I can find are the complete sets...
Anything else I should try or consider?
Thought about pulling the passenger side coil to rotor wire and trying it on the drivers side to see if engine will start. As I recall, removing this wire will require removing pretty much all of the ignition and plug wires. Then if it works, I still need the replacement wire for the drivers side...
