Well, I removed the hose, once upon time it definitely had a clamp on (pressure imprint), no clamp in site though...  It is in surprisingly good condition (other than grime), not sure if it's been replaced, but I'm replacing them all, made a list, will place the order on Mon.
For the time being, and while under the hood, decided to clean things up, and reconnected that breather hose.  Ran the smoker again, no leaks to be detected, so that makes me happy, and will be glad to have all the new hoses that will last a while...  On down side, the rpm drop/choking under quick gas pedal press remained
I decided to check if any codes are present (none were there after I replaced the LH module with WOT, cleared all and checked in few days...  that was almost a year ago) Well well...
Socket 4 - 4 blinks:  Voltage at air mass with hot wire circuit.  Open or short circuit.
Actually, come to think of it, when I first bough this car, after few weeks of tinkering with it, I remember it did have similar behavior, RPMS would drop with quick gas pedal press.  The car did come with new (remanufactured Bosch MAF), so I didn't really take MAF as consideration for the culprit, and replaced all the vacuum lines and bunch of other little things that the car needed anyway.  And while it improved (dramatically), RPM drop remained)
Used $65 MAF via car-part.com arrived, and it solved the RPM issues and rich running smelly exhaust.
Well, this is that old used MAF that served me well for 3+ years
I'm not a hoarder, but I have accumulated few parts of the years here and there
And I've had a spare MAF from pick-a-part off W140 from last year, plugged it in, and voila
Exhaust has almost no smell to it (it was getting a little rich lately) and no more RPM drop!!!  Semi-assembled everything back, drove the car for almost an hour at various paces, no drop, no stalling, no hick-ups
Came home, let it idle for 35-40 min while paps and I seat on the bench under the tree and enjoyed a beer.  The car didn't die, RPMs didn't jump, no gasoline smell in the air at idle!  So I'm assuming that culprit was the breather hose and MAF (this was my last spare), can't wait for all the new bling-black hoses/pipes to replace.  Also noticed rub mark on the under side of the strut brace, that can mean only one thing:  I need new motor mounts too!  But that's another topic...
Cheers all, appreciate all the know-how and the resources!
D
