WANTED Sportline LCA right side 124-330-37-07
If the joint is clean and intact, and has zero play, replace the boot with new OE. This can be done without removing the LCA from the car, alignment not required afterwards.
May not be a bad idea to buy the spare LCA just in case, or if there is obviously water/dirt in the joint from the torn boot. There are a few left, for now, maybe. Have your dealer dude check Paragon.
No right side ones available, a couple lefts are left.
GSXR How do you replace the boot? I bought some MB ones last year and my mechanic said it couldn’t be done 😬🤦🏼‍♂️
Did they check worldwide inventory AND ALSO dealer inventory?
Straightforward R&R. Your mechanic is wrong, or doesn't want to do the job. I've done this personally several times. Worst part is getting the circlip re-installed without damaging the brand new boot...
Straightforward R&R. Your mechanic is wrong, or doesnt want to do the job. Ive done this personally several times. Worst part is getting the circlip re-installed without damaging the brand new boot...
Yup checked worldwide at the dealership.
Could be both my mechanic is wrong AND doesn’t want to do it 😣😣😣
Right sportline LCA went NLA over a year ago, this dose not surprise me. Apparently there is company in Poland that can refurbish this arms, please don't throw away your old LCA. I don't have bad LCA at hand to send to them, so I don't know if this is true or not. 🤷‍♂️ Maybe they just install new boot IDK.
