Not sure if it's been posted, but that the kit from thekangaroosteam.com I just stumbled on: 345MM 4 PISTON BREMBO FRONT BRAKE KIT - W124 / W201 / R129 - The Kangaroos Team
The bracket adapter is the key to make it work!
"The kit is made to replace the standard front braking setup, it`s easy and quick to mount and fits almost all 17 and all of the 18 inch wheels . Here are some specs: - You get 100% what you see on the pictures! - 100% refurbished Brembo 4 piston Aluminum calipers from w220 s500 (new pistons, rubbers and etc) - 2x ATE 345mm drilled discs with the proper offset (not w220 ones) - a set of ATE brake pads - 2x teflon braided brake hoses - all the necessary adapters, shims, nuts and bolts for making this kit a complete bolt on to your car "
"975€ Shipping: DHL Express 298.00€ " <-- total ~€1275 / ~$1350 USD delivered
