Hello Folks,
I must admit that this is my very first time like I am joining online forum, usually I was able to work out things myself and with my mechanics, until now...
I have searched through many records but still cannot pull out anything that would clarify in 100%, therefore could you please help, and if I missed anything on forum, could you please drop me a link or clue, or both
I have a 722.6 transmission that needs:
a) immediate fluid top up due to pulsating noise when cold, which almost goes away when warm
b) entire fluid change (have appointment in 2 weeks) as it has never been done in my opinion, but there are questions appearing with no answers so far
I have just purchased Febi dipstick and checked the level, which is clearly 2 - 2.5 cm below required level, gears are incredibly smooth but pulsating noise is assisting when accelerating. I was looking to make a top up and here is where the problem starts.
Fluid is light yellow in color, almost clear, which would indicate that 236.10 oil is been used from the day 1 and possibly never changed over 20 years.
There are no yellow in color fluids available around in Ireland after initial search - I have been thinking to let my mechanic perform static change, using identical color and specification fluid.
Would anyone know where could I purchase such oil.
Can I use different color fluid with the same specs of 236.10 for top up and static change.
Or do I need to tie up with MB for dynamic change and hope they would have 236.10. And does it matter if new 236.10 will be in red, with no harm to the gearbox.
I would prefer to avoid using thinner ones.
Please advise.
Thanks in advance.
Please advise.
Thanks in advance.
