WANTED Working HVAC pushbutton control unit (for automatic climate control)
744Brillantsilber
Moderator update: Thread title edited to clarify request.
Looking for a working AC/heater control unit, for the automatic (American) system.
Please let me know if you have one
I have an available ProgRama refurbed unit, never installed…
But I can’t imagine there isn’t a similar one availabile closer to home
Merlin, I took the Canadian Celsius unit off of the 500E and replaced it with one for the U.S. market. You’re welcome to have mine if you’d like.
If the Celsius unit one is not taken, would like to see if could aquire it. Would have F one available then as have a spare.
I’m looking for the F digital display for 500e. Mine shows temp then shows 20 degrees less. Have traded to the display. Is that what you have?
Have traced to the display I meant.
Just FYI guys - your request is for the outside temp.display unit, while this thread title is for the HVAC push button unit. So your request may not be snatched up by anyone.:)
Mine is for a push button hvac unit. Would like to swap f unit for c unit if otherwise they would work.
No need to swap the entire HVAC unit. Either get new colored strips for the temp wheel, or swap the temp wheel itself. The controller is identical otherwise.
:banana2:
