OWNER Surf Blau (Norsker)
Now, another thing I'm unsure of is the sound my air pump makes - it does sound like an air pump (duh!), but it's fairly loud and I'm wondering if its supposed to be like this.
The air pump should be fairly quiet. Like, almost silent, but not quite. You should barely be able to tell it's engaged, over the noise of the engine at idle.
It also shuts off when the ASR-light comes on....
now THAT is weird!
and I've never seen it engage again before I start the car again. I've attached a video showing the sound and it shutting off.
Once it shuts off a few minutes after a cold start, it MAY turn back on randomly (even at full operating temp!), but often will remain off until the next cold start.
:v8:
Hmm, based on your info I presume the pump on my car is about to go out perhaps? Are these different on different cars, or will any pump from an M119 with the correct amount of tracks in the serpentine belt fit?
I read somewhere else here that the pump normally shuts off after a few minutes, and as the ASR-light goes out after 3 minutes it might just be a coincidence.. As I mentioned I've never heard it engage again outside of startup.
All the M119.97x air pumps should be interchangeable, I think, just match 6-rib vs 8-rib pulleys (they are different diameters, IIRC). There are some threads and videos about repairing / refurbishing the pump internals. Might be worth trying to open it up and clean it?
Could be coincidence. The pump not running isn't a problem. On a car without CEL (anywhere outside North America), if you disconnect the pump, the only result will be a fault code on pin 4 / LH module. The only purpose is to reduce emissions during the rich condition of a cold start.
:bbq:
Do I understand you correctly if I think you're saying that nothing besides the pump not working will happen if the pump has an issue? Ie, it won't seize to an extent that the belt an possibly other auxiliaries might be damaged?
If the pump is electrically disconnected, the clutch never engages, and the internal parts do not rotate. As long as the bearing is good, the pump would then act as an idler pulley. The concern would be if you leave it alone and it continues to get louder during operation, eventually it could seize or otherwise cause a problem.
Right, that's what I feared - or rather, I was hoping that it would disengage by design if/when it fails, instead of locking up and most likely damaging other components while doing so. I'll keep my ear on it and disconnect it if I hear an increase in sound.
I've not wrenched on the air pump, but like to mention maybe a parallell in case it goes down; I had an AC compressor breakdown on my exLimited, where it fully seized. That means when the clutch engaged it released immediately due to the resistance in the locked up compressor. I always keep attention to strange noises in the car, so I was surprised when the AC mechanic told this and I hadn't noticed anything! But he said with an engine torque this high even at idle, it would hardly be noticeable, just a small dip in the idle before the clutch releases. So if the air pump breaks down/get seized, the clutch will release and no further harm occure - supposed the clutch and its bearing is fine.
I don't recall why I posted in this particular thread, but post #21 has images of the seized AC compressor:
I wouldn't call that a bearing-related sound, but from your experience stuff can hit the fan without a more noticeable sound as well I guess.. I hope you're right, and will keep an eye on it for now - should be easy enough to disconnect in case it gets worse 🤞
So, tonight the 500E left me stranded at the local grocery store. It hasn’t been used for a week or so, but still started up as if nothing had happened. I drove the 5kms/3mls to the store, did wonder why the steering wheel was vibrating slightly, but as I didn’t feel anything through the shifter I figured it was a bit of flatspotting on the front tires from parking the car with warm tires.
I did my shopping and started the car, again as it normally does, but after a few seconds it started sputtering and died suddenly. No amount of cranking would bring it back to life, the only sign of such were occasional loud bangs from the exhaust. I removed and inspected all plugs and connectors I could reach with no help, and messed around for a good hour before it finally «ran» again - although dying as soon as I shifted into D or touched the accelerator. Shortly after I was able to make it run well enough to shift into gear and limped home, while feeling the car becoming its own self again by the minute. When I was back home it idled as if nothing happened.
I removed the distributor cap on the right bank and found corrosion and moisture inside. Now, I’m sure the best advice would be to replace everything, but before doing so I wanted to hear if anyone has had good luck cleaning up these parts and using them for a while longer?
Yes, as GSXR said, this is the classic moisture in the caps problem. This is a living problem and I was badly punished on this many years ago:
That happening led me to cutting additional slots in the caps to improve ventilation. It was some headshaking around for doing that, but living in Morepay with cosmic parts pricing I had to do something. It worked out very well and some years later the same idea was introduced as the first walk on the moon by somone else.😊 However, all are happy and that's the best part. And even better, it's been proved that the caps can be used for years. It's no reason to panick from burnt contact points and green goo inside, just clean them up and put them back again. The rotors are a bit different having other wear points.
I just picked up a set of used caps for around 35USD, so I'll try to modify these and see how things go - if it hadn't been for all the encouragement and positive mentions of this mod here on the forum I would have joined the headshaking myself as well 😄
Yesterday I received the first batch of parts for the 500 - there will definitely be more batches, but I had to start somewhere. Generic parts like oil and brake fluid as well as filters has come in a long time ago, I just haven't had time to work on it yet..
So to what I got yesterday;
  • Flex disc repair kits + support bearing for the prop shaft; Hopefully this will take car of a bit of clonking when I go on/off the accelerator
  • New brake discs; I occasionally have a bit of vibration when braking hard, so when I found these discs from Brembo in the correct size and directional setup, I figured it was worth a try.
  • All new bushings for both sway bars; Also in pursuit to rid the car of minor clonking from the suspension.
  • New insulators; Figured it would be a good preventative replacement in combination with modifying the distributor caps. These came fitted with the gasket that I also got separately..
  • I asked my parts vendor for the clips that hold the sacco board on the front right fender on as this is a bit loose, and was told there are six different ones for it! Ordered some extra just in case..
As mentioned I am chasing come clonking that I hope to fix with the rubber on the prop shaft itself, but I will also try to source new engine mounts and transmission mount. There is also a bit of clonking from the steering which I need to sort out, as well as some rubbing from the contact rings for the steering wheel..
Sounds great! Let u sknow how it turns out.
I've noticed the drivetrain "clonking" when going on/off throttle on multiple different cars with the 722.3 transmission. I believe it's something internal to the transmission, not in the propshaft / differential / axle shafts.
That's interesting. My 500E has an occasional distinctive "clunk" when applying the throttle - which I've always (without any scientific evidence) put down to a worn differential. It can be avoided by gentle opening of the throttle.
Will do! I have good experience with the prop shaft rubbers on other cars, where I have also had to do the rear subframe mounts on some - hoping it won’t have to come to that though, but we’ll see..
In case you bought FEBI flex disks, can you check if they are reboxed SGF disks?? If so, where did you order?
I am also in need of a complete set of flex disks and want SGF.
That’s what I’m hoping as well - will inspect and let you know asap 👍
Oh, and I got them from MBenzNL in the Netherlands 👍
Aha, from Steve of course! So he is still in business, haven't checked his site for years, I have to take a look.
Many thanks! :thumbsup2:
BTW - I hope the 500E poster arrived without any shipping flaws, and was up to your expectations?
He is very much in business still, although they are actually in Norway for vacation at the moment 😄 His website got poached a few years back, and as he wasn't interested in paying the ransom for it he now relies solely on word of mouth and the occasional FB-post (where he still has a page). In other words, you won't find his website any more, and the best way to contact them is through MBenzNL@gmail.com or a message on FB. I might be ordering more stuff from them in the near future though, so perhaps we should join forces and save on shipping if you need parts as well.
And when it comes to the poster I honestly haven't opened it yet - the packaging looked fine and thus I trust that the content is ok as well. It will either go on the wall in my soon-to-be-"finished" workshop in the barn or home office when I do finally get around to hanging it up. (y)
Thanks for the idea on parts purchase and bundle shipping, we should save some on that. I need quite some parts, mostly rubber based parts like the flex disks, shock tower mounts, cam chain rails, all kind of suspension bushings etc...
As for the poster - I wrapped the poster in plastic foil to keep it rolled up inside the box and for moist protection during shipping. But it shouldn't be stored with the plastic due to risk for condensation inside the package over time, dependent of where you are keeping it. So please take off one of the end covers on the box.:rugby:
Today I finally had a chance to inspect the underside of the car thanks to a new lift I installed recently - I know, buying cars like these without a thorough inspection is a bit crazy, but I've made it so far relying on my instincts (even buying a 1966 250SE online) and luckily it wasn't as bad as it could have been after 220.000kms/137.000mls 😄
As the car has previously spent some time in the UK, a country which for some reason seems to be synonymous with shoddy repair work and rust on older cars, I've had a fair few times waking up in cold sweats from nightmares finding a completely scrap underside on the 500. From now on I can sleep a bit better.
A bit at least; What I found was a mostly solid body (relax, I'm talking about the car), mostly decent rubber (still car) bits and an exhaust system with one foot in the grave. In addition to no apparent or major leaks, a lot of random black shiny sprayed on substance I assume is ancient rust prevention. I have attached a random selection of photos from the underside for those interested - feel free to comment if you have tips on how to proceed or more knowledge than me on the apparent condition of my 500E :)
IMG_3157.jpeg IMG_3192.jpegIMG_3189.jpeg IMG_3186.jpeg IMG_3181.jpeg IMG_3180.jpeg IMG_3177.jpeg IMG_3173.jpeg IMG_3172.jpeg IMG_3170.jpeg IMG_3162.jpeg IMG_3160.jpeg IMG_3164.jpeg
..and a couple of exterior shots after a quick hose-off before a longer weekend trip starting tomorrow.
Looks great! Only item of concern is the rust below the battery box. You'll need to excise the rust and repair the holes, which will take some effort to do properly.
I see Kitty has approved as well!
Indeed, she gave it two paws up 😄
I knew about the rust under the battery box before buying the car, so that didn’t come as a surprise lucikly. Having had a chance to inspect it more thoroughly it does appear to be less of an issue than first feared though - it will take a bit of work, but as you say it can be fixed and should be possible to do even without the proper replacement panels available! (y)
Rusty battery box...no good. No panels available..so you ideally need to find a good non rusty donor part, if to repair it correctly.Have a look at my owners thread..i did this job on my previous 500e.
You experienced a textbook case of moisture in the caps. Follow the instructions in this thread to cut additional venting slots. It's likely that will resolve the problem. Also make sure there is no oil leaking from the intake cam solenoid/magnet down to the lower edge of the cap, and that the exhaust cam sprocket seal is good.
The corrosion isn't an issue, 20kV will blow right through it.
Update on the misfiring; Cleaned up both distributor caps and rotors as a temporary measure, and the car works as expected again - it even feels like it is idling smoother than before, but that might just be my imagination. Found a set of good used caps and rotors (at 20$) that I plan to modify with the recommended venting slots. I will inspect the insulators upon installation, but frankly don't expect any issues with these as they look pretty new and I don't experience any other symptoms of misfiring.
Now, another thing I'm unsure of is the sound my air pump makes - it does sound like an air pump (duh!), but it's fairly loud and I'm wondering if its supposed to be like this. It also shuts off when the ASR-light comes on (still haven't had time to renew the brake fluid :whistling2:) and I've never seen it engage again before I start the car again. I've attached a video showing the sound and it shutting off.
Official "HOW-TO" coming later today on remediation of this problem.
Cool, I'll check it out! I guess finding the proper metal parts will be close to impossible as I'm not the only one in need and the supply is scarce though..
:p
Made it to and from our destination for the weekend without too much hassle:
But there were a couple of things I noticed along the way and need to investigate;
- After a couple of hours of driving we stopped in a village, and as I engaged reverse to park the car, it began pulling backwards unevenly, as if it was slipping or the engine was misfiring. Never had this issue again though..
- Going onto a larger road I gave the car the mandatory kickdown-treatment to get up to speed as quickly as possible (the engine was nice and warm), and for a minute or two afterwards it seemed to run unevenly. Never felt this before or after again though.
- There is some slack in the left front suspension, which I first suspected to be a bearing in need of tightening. After some investigation the bearing seems fine though, which makes me think there are components in the steering linkage that needs replacement. It's either that or the dreaded lower control arm 😬
Besides this the car ran fine - as expected!
As implied in another thread here, there is some unwanted noise and feel to the steering of my car. Basically there is some clicking/clonking when turning the wheel, and generally a loose feeling and clonking to especially the left front wheel when shaking vigorously in/out sideways. At first I expected the bearing to need tightening, but this turned out to be perfectly set and there were neither no signs of it getting unusually hot under the grease cap.
After reading said thread and following the discussion there, I had renewed suspicion that there had to be issues in the steering linkage, and today I finally confirmed this. Even just shaking the components by hand (with an assistant in the car holding the steering wheel against the steering lock), there is noticeable slack. My plan is to order new tie rods, drag link, steering damper and bushing for the idler arm and basically replace all of them simultaneously - might not happen before winter hibernation kicks in though. Now, I've read posts saying that one tie rod and the idler arm kit is NLA, and also that the OEM parts might not be what they were anymore - so, any tips on where to get these parts and be sure that they are good?
Also; One of my keys stopped working all of a sudden - or more precisely; The car does not respond to the IR-button any longer. I checked the IR-light through a camera and it seems to work fine and there is no difference to how it lights up compared to the other key. Writing this I realize that I maybe should have renewed the batteries and tested it again before whining about it, but hey, I'll ask anyway; Is this normal behavior for low battery voltage?
Tie rods - read post #9 here
Idler bushings - read post #11 here
AFAIK all the OE/Genuine steering items are still good quality, or at least there are no better aftermarket items that I know of.
The quality concern was more related to some rear subframe components, where manufacturing has moved out of Germany to low-cost countries.
:hornets:
It's generally not much info here on the forum about the IR-locking system, but you should find some on the internet. I slightly recall that a low battey was an issue on my exLimited, even though the IR light in the key fob was visible. You could take out the battery and leave the key fob for some minutes as well, then it should reconnect automatically to the car at first use. I don't recall the connection process, maybe it was something with pressing the key until the red light in the door starts blinking, but take that with a grain of salt.
Thanks for the input! I kinda forgot about this as the issue happened to the spare key, but now I looked into it some more and tried the obvious first; Renewing the batteries. At first there was no change, the IR-function was still inoperative, but after a minute or so - or more specifically unlocking and locking the car manually with the mechanical key - it worked like a charm again. I don't think the manual procedure was related to the "fix" of it, but maybe there was some sort of magical re-learning or re-connection going on. No idea, for now it just goes on the list of things that work themselves out 😄
Still no updates on the 500E steering components; Waiting for my parts supplier to try to find alternate parts for the NLA-parts, and have spent the time waiting to prepare my CLS Shooting Brake (aka the Winter Beater) for its bi-annual inspection.
Winter is fast approaching where I live, and we have already had night frost, which came earlier than expected. I'm not sure how long before the summer cars are parked for the season, but hope to get some components replaced (and the results tested) on the 500E before I do so. No other projects planned for the other cars on this side of winter though, besides general cleaning, detailing and preparation for storage.
With the lift in the barn finally installed and working properly, next season should start with a lot of servicing (unlike this season) and particularly change of "all" fluids and filters. Hopefully that will rid me of a lot of guilt then! 😄
Received a package of goodies yesterday, with all steering related parts as well as filters and minor parts for fuel and transmission. Now all I need is to find the time to actually replace parts and not just order them - I already have a huge pile of parts ordered just after I bought the car 😄
I don't really understand why the A129 330 02 03 and A129 330 03 03 are different parts though, they appear identical to me...
@Surf Blau - Good job geeting some good parts on order. I am curious how the engine mounts provided by Kurth look / smell / weigh.
HOW TO: Replace Rear Subframe Bushings with Miller Tools | "HOW-TO" Tutorial Articles - Good thread for reading up on the smaller subframe mounts. If you can still find the factory 'tall' subframe bushings, go for those. They were either within a Febi Bilstein 10154 box (don't think this is the case any longer), or you can look up just the bushing as it is: Boge 2-33-001003. If those arn't able to be found, you can go for 'normal' short bushings and they'll be in improvement still if factory rubber is looking rough. 124-351-19-42 is the part number for those factory OE bushings.
I’ll make sure to document the parts and give an opinion on their quality once I receive them! (y) Kurths is pretty renowned though, which is also one of the reasons why I didn’t hesitate.
These are the ones I’ll (expect to) be getting, which to my fairly new 124036-eye look like the correct shape at least: Rear subframe mount from Kurth
Based on the photo, description, and price... I have a feeling they are selling standard OEM mounts, which are technically "suitable" for Sportline/E500E applications... but are not technically accurate.
I'd prefer the later design which looks completely different, and is far more robust. Those are NLA as OE/OEM, but there are decent replica mounts available.
The forward/smaller bushings with "tall tabs" are difficult to find these days as OE/OEM/Boge.
So there is a similar issue with the rear ones as well as the front ones? I notice Kurths doesn’t even offer the front ones,
I read in the thread that @dreaming.haze linked to that the proper ones were available as certain aftermarket parts - does anyone know if this is still the case?
Scored some original rims for the 500 yesterday:
Not exactly mint condition, but they were offered as “winter tyres for W210” and thus fairly reasonable - I’ve been wanting a set of rims in the factory paint finish to keep the car as original as possible, as the (original) wheels that are on the car have been refinished with diamond cutting at some point. I like this finish when they are clean, but it looks a bit meh once dirty. The plan is to make the new set as nice as possible and keep as a spare for now.
The pile of 036-bound parts is growing. Today I received a package from Kurths with 2x engine mounts, 1x transmission mount and 2x rear subframe bushings.
The transmission mount seems well made and all, but is surprisingly soft the first few millimetres:
Am I right in thinking that these are humdrum subframe mounts, not 036-specific ones (nor sportline)? I seem to remember that there should be some rubber ears/supports on either side of them, not just the underside (or technically upper side)..
The old, original-style rear subframe mounts used on all 036 chassis and all Sportline undercarriage, looked identical visually to standard mounts. I believe the only difference was stiffer rubber (higher durometer). If the mounts supplied by Kurth are reproductions (not NOS Mercedes/Boge), there's no way to tell what the rubber durometer is, compared to original stock or Sportline/036.
These old Sportline/036 mounts were superceded to a newer design that is MUCH more robust. There are aftermarket reproductions of the newer design offered by Carus and other vendors. NOS mounts show up for sale occasionally as well.
Edit: The stock, standard mounts are still available new from Mercedes. P/N 124-351-02-42, currently $53 MSRP each in USA.
Pics below from W124performance:
Welcome to the forum! Your car looks lovely and I'm sure you'll get all these systems back to a new point. The NLA and parts availability is a bit fun with these.
To your note on 500e badges, we did a group buy a few years back were one of our members reproduced badges in factory specific look. I've got a couple floating around here somewhere if you'd be interested in it.
Sorry, just spotted this. I took mine off before someone else did.
Aha, I see - thanks for clearing that up, I thought there was a visual difference as well.
Many moons ago a friend of mine were modifying these bushings regularly with added polyurethane, both filling the voids of good bushings but also replacing all of the rubber with solid polyurethane on worn out/donor ones. I seem to remember that we found a way to differentiate the different types, and came to think of this again when I noticed that these new ones have a roman number “II” stamped into them. I’ll check with my friend and see what he remembers.
No worries - and smart choice, considering the prices these go for! I actually got hold of one of the reproductions from the forum initiative, but haven’t gotten around to put it on the car yet. I also got hold of a “200D”-badge and have been playing with the idea of making them both magnetic and alternating between them in honor of the previous owners of the car..
I talked to my friend about the differences in these bushings, and the only thing he could remember was to have measured different sized air gaps in them. So I guess one way to check new bushings vs old (and confirmed 036-specific) ones is to measure the distance between the center and outer rubber parts.
View attachment 229661 View attachment 229662 View attachment 229663
Magnetic? Makes it even easier to steal.
