Eric, the other 124 in the photo is Jano's Euro 200E with the body kit. That car didn't run as it would have been too slow, although it would have been fun anyway. The 210 ran a best of 155, btw. I figured Jano had the .036 covered and I'd bring down something different to play with!
Also, Dean's car is a bit modified (wider wheels = more drag, roll bar = more weight, larger brakes, etc) which can all add up a bit. If Dean had a full tank of fuel and spare tire, that was a solid 125 lbs of ballast which Jano did not have.
Several people asked if my EVO II rims were stock. Am I supposed to answer yes or no? It's really more of a semantics issue, I answered "yes". *shrug*gsxr said:Jano's car is stock except for the LH module, btw.
We might have to nudge Eric towards attaining a 036 in order for that to happen. I do hope the ¼ mile strip in Fontana opens up, but I feel we’ll have a better chance of meeting at the next Mojave Mile event than in Fontana. So head to head racing might have to wait, unless the 1/8 mile track is of any interest. Not sure what other tracks in SoCal hold street legal races on the weekends, maybe Eric or Justin know. I don’t think the Pomona track holds street legal races on the weekends, or at all.to see if your car is quicker than other 500's would be to square up against Steve, Justin, and Eric at the dragstrip if/when it re-opens. Now that would be interesting!!
Still an M119 though, no M113's for me. Just say no to SOHC!
No need for one. I doubt I'll be hitting 150mph, plus the 300V Motul oil I'm running now is for track use as well, so I'm good to go.You might want to install the Euro market engine oil cooler before you engage in that type of racing. (If you haven't already.)
Not from what Porterfield told me earlier, as well as feedback from a few racers who been using R-4's on the track, on various cars. The bed-in period for cast iron and steel alloy rotors is minimal. A lot of racers also mentioned that the warm up time is minimal in between sessions. Regardless, I plan on installing the R-4 pads a week prior to the track date and drive to Willow Springs and back with R-4's. A few racers mentioned that the R-4 pads felt good driving to the track, tracking and driving back home with them on. Some even went as far as keeping the R-4's for street use.Not rotor-friendly, and don't work when cold... need a few corners (or laps) to get them heated up.
I wouldn't be surprised.Wow. That is VERY different from what I had been told a few years ago. Maybe they changed the compound or something...
What was the problem/concern with 660? I will not be leaving racing brake fluid in after the track, brakes will be bled and DOT 5.1 will go back in. No LSD on my car, this is my DD and I'm not trying to turn it into a track car.I ran 660 in one of my cars..can't remember which one.. buying a case of SRF solved my problem/concerns. Not sure about the Motul but the SRF you can leave alone for a number of years w/o worry of moisture...works out pretty well
Are you running a Quaife/LSD of any sort?
jono
Maybe if I work it just right I'll find a cop right @ the end of the run and he can give me a verification of my terminal velocity..;-)
jono
tonight's fun you ask??...mucking about w/ a recalcitrant CISE M119..Wooo!!! @ least I have WOT performance back and my artificially low redline solved. Now to see why part throttle is lack luster. Going to go add an extra O2 bung in a bit once she cools down..
jono
Yes, it was absolutely distance limited! Almost all stock MB's will need much more than 1 mile to achieve top speed. The gearing is almost irrelevant, that will only change the time required to hit the mile, while having almost negligible effect on the trap speed.I would have thought that 140 would be possible with a stock SEC/SEL, so I wonder if he was distance-limted..... also wonder if he was using the stock US 2.47 rear end....
..and the diag trees in the service manuals are ridiculous..
....along with B& trick shift.
jono
Very, VERY slow. The more I drive the W210, the more I like the 722.6 transmission, and the less I like the W210 overall. The E55-K might get my attention, or one of the new 63's (E63, etc), or any twin-turbo V12. But all of the above are out of my price range by an order of magnitude or more. If anything, I'll be adding to my 124 collection!!Michael: Dave is on a slow, but steady, evolution away from the W124 toward more modern MBs.
