The chip you were testing WASN'T Dernt's chip! I'd like to see some tests on HIS chip!
If he had the eBay chip, it was the same chip. The eBay guy only sells a single chip program for all LH M119's.
			Again, one of my dyno runs was with a 92 ECU WITH A 5.0 CHIP! And it wasn't any richer than a same part number stock 92 ECU. Dernt's chip is different than the ones that we are stuck with! We need that chip or another one from the same outfit!
Was your dyno run with a 92 5.0 chip, or a 93-up 5.0 chip?
			Dern't had TWO 400Es. his original stockish one (the one that he dynod the chip with), and the 6.0 RennTech one (the one that Justin tried to get). Which one got crushed? What happened to the other one? Is he into something else now? Maybe he doesn't want that chip anymore? Maybe he doesn't need his N2O system anymore either? Maybe he doesn't need is 6.0 anymore! We need to talk to him! Wait a minute...... Maybe you are already talking to him about his 6.0?!?
It was the 4.2 that got squished in Jan-2012. Photo attached, hopefully he won't mind that I posted it. Last I heard, the other car was still in FL and he doesn't get down there often.
			Would you please tell everybody here how much better your 036 runs when the weather is cooler? Don't look at it as backing me, look at it as backing Uncle Gerry!
To be more specific. I've said this before but I love repeating myself. Lower ambient temps generally do help slightly. But that's it, slightly. There is not a 3 tenth improvement between 80F and 50F. There is not 20hp for 15 degrees, or everyone would be getting 400hp from their 500E's in New Yawk winters.
I looked up some data from my car this year, in 60F in spring it was running consistent .35's (±0.03). Skip forward to summer, in 90-92F ambients it ran .45's with similar fuel load, wind, etc. In 100F it ran low 50's. Only 0.15 slower with 40F hotter ambients? Hmmm. But yes, it was slower, Eric and Gerry are technically correct. Uh-oh.
OK, so my car is weird. Let's look at my wife's 500E. On the 60F ambient spring day, it was running low 50's. In 90F it was... high 50's? That can't possible. Same fuel load, similar wind, etc. 100F ambient, ok, it finally slowed to low .60's, a bit over a tenth slower with FORTY DEGREES HOTTER AMBIENT TEMPS. That's completely, totally, inexplicable unpossible! And this wasn't a single fluke day, we had four different summer race days with 100F ambients, the data was similar on all of them. In the fall, her car ran a string of consistent low 50's in... 52F-58F ambients. Uh-oh, her car ignores the ambient temps even more than mine. Rut-roh!!
Slower in the heat? Yes, but not as much as everyone implies, nowhere near one tenth per 10°F. The bigger difference is that in the cool ambients, I can get the engine down to 60C between runs. In the summer, it's usually 75C.
Side note: We drag race with a 20C fixed resistor in place of the IAT sensor. Maybe that has something to do with the consistency? I'm not sure, but in the interest of full disclosure, I figured I'd toss that out. Photos attached, it's a factory "tool".
			gsxr is extremely obdurate about this topic.
Yes. Yes, I am.
