Hi, i switched from the double fuel pump package to the later style single fuel pump. This design is better because its just one Pump to pay for, its stronger (more Liter per minute) at same pressure (4 bar) and the pumps are close to non-audible - they are very silent. Mercedes switched to this Design in nearly all Benzes at the very End of the Year 1994. The Bosch or Pieburg OEM Pumps are very reliable. Usually they last 10-15years if you change the fuel filters regularly, in order to reduce backpressure to work against, for the pump.
The switch to single pump is actually quite easy and if you already have old or noisy pumps, i would consider a switch to the single fuel pump. Here is what you have to do and to get:
Parts List in EPC:
I Ordered the Bosch Pump with Part-Nr. "Bosch 0 986 580 372". I was a little disappointed because they are no longer made by Bosch Germany themselves, they are now made in Poland by a company called "TI Automotive" and there is just a Bosch sticker on the pumps. I assume TI Automotive is owned by Bosch anyway. Same like the new Bosch Coils that are made in Slovenia by another company and only have a Bosch sticker on them nowadays... Well but thats a different story.
Installation is quite Easy:
1. Jack up the rear of the car. I used two ramps to drive on them. Or use a large car jack to have enough room while lying under the car around the fuel pump area, near the right rear wheel. At best use a car lift. Remove "-" Pole from battery and secure it. Better safe than sorry.
2. Remove the plastic cover from the Pumps. Its just a few 10mm Plastic nuts.
3. Use a hose-clamp to clamp/block the thicker rubber fuel-line/hose coming from the tank
4. Remove electrical lines from the old pumps
5. Remove fuel-line from tank to the first pump
6. Cut the fuel-Line from the old Filter to the steel fuel-line that later ends in the engine bay. See the Pics for at which length to cut.
7. Pre-Assemble the whole new unit (pump with new filter and short fuel inbetween them + the new metal braket/holder).
8. "Hang" the new Unit in its place with the 4 little rubber hangers. Now connect the electrical lines. I used to isolate two of the four lines, because you now only need two lines for one pump obviously. You can see them covered in layers of "Wire Harness Tape" on my Picture. I assume you also could just connect all 4 lines to the pump aswell. But it was too much hassle for me since then you have a problem with the rubber covers of the other two electrical lines.
9. Connect the Fuel-lines from Tank to the pump and from the filter to the previously cut fuel-line.
10. Run the car and check for leaks.
11. Reassemble the plastic cover around the pump.
12. Enjoy!
Pics:
The Principle of the single pumps flow is simple:
Fuel Tank -> Larger Hose -> Fuel Pump -> Smaller short (approx. 120mm) hose -> Fuel Filter -> Medium outer diameter hose -> Steel fuel line -> Flex line engine bay -> Fuel distributor ring -> etc....
Parts List in EPC:
12. Enjoy!
Pics:
