All,
This is a frustrating one, because... well.. it is really hard to TEST.
The issue:
I have a 1995 E320 Wagon (maybe important? Tailgate?) with the Ortho seats. The ortho seats matter, because the central vac system is different. Anyway, I can lock the car normally (with the key) from the drivers door, or the passenger, or the trunk. Everything works fine, and all the locks work. Central lock works fine. However, at some point which seems like something between 15 minutes and more than 24 hours, the car unlocks itself. All the doors. They all unlock.
So I drive somewhere (or leave it in the garage) and lock it. Everything locks, seems fine, no sounds, etc. I wait for a minute or so, and nothing happens. Then I walk away, and come back some time later, and about half the time it is unlocked. I have tried to figure out pattern, but I cannot.
I figured at first it was the drivers' door lock mechanism (the vac plunger), so I bought a new OEM (mercedes part in mercedes box) plunger, and installed it. Nothing changed. Then I ordered (it was expensive) a band new Central Locking vac (under the rear passenger seat) and installed it. Fired right up, made vacuum, and everything seemed fine (no obvious leaks, etc). No change.
I have not replaced the passenger door plunger (though I have it, so I could), nor have I touched the tailgate lock.
But I am not really sure how to diagnose this silly thing. And the parts are just annoying enough to replace.... I dont own a smoke machine to test for vacuum leaks, but could probably go find one.
Any guesses on how to actually figure out the culprit?
P.S. This is an issue other people have had: Help! W124 unlocking itself at random!!! - Page 1 - Mercedes - PistonHeads UK
But no one seem to have a good way to test it.
Thanks!!!
-Dan
The issue:
Thanks!!!
-Dan
